Home » Archived » M2M (model-to-model transformation) » [ATL] how to use xsi:type in atl input model file
[ATL] how to use xsi:type in atl input model file [message #2940] Thu, 28 December 2006 00:03 Go to next message
Hello ,
i am using xsi:type in my model input file. my sample input file is
following.
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:a="bpdm">
<a:BusinessProcessDiagram Name="BusinessProcessDiagram1">
<Pools Name="Pool1">
<Process Name="Process">
<GraphicalElements xsi:type="bpdm:Task" Name="task1"/>
</Process>
</Pools>
</a:BusinessProcessDiagram>
</xmi:XMI>
where entity GraphicalElements has a EObject type.
when i tried to run this using rule
rule bpmn2bpel
from input : bpdm!BusinessProcessDiagram
do {
input.Name -> println();
it gave error .
An internal error occurred during: "Launching".
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:226)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:154)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:136)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:117)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:95)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
when i removed <GraphicalElements> entry from model so it works fine.
but i don't know why it is not working with <GraphicalElements> tag.
pls help me.
thanks in advance.
Brajesh K.
Re: [ATL] how to use xsi:type in atl input model file [message #2959 is a reply to message #2940] Thu, 28 December 2006 03:43 Go to previous messageGo to next message
ATL does not directly handle XMI reading and writing but delegates these
tasks to the underlying model handler (e.g., EMF or MDR).
Therefore, in your case, you should rather refer to the XMI
specification implemented by EMF and/or ask this kind of EMF XMI-related
questions to the EMF people.
Note that you can also use the EMF reflective model editor, which let
you edit your model visually (with a tree-based syntax). If you do so,
you do not need to even care about the XMI: the editor generates some
file (it could even not be human-readable for that matters) that ATL
understands because both use EMF.
That said, my guess is that you should write: xsi:type="a:Task" (i.e.,
use "a" as prefix instead of "bpdm", which is the URI).
Frédéric Jouault
brajesh K. wrote:
> Hello ,
> following.
> </Process>
> </Pools>
> </xmi:XMI>
> rule bpmn2bpel {
> do {
> it gave error .
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> pls help me.
> thanks in advance.
> Brajesh K.
Re: [ATL] how to use xsi:type in atl input model file [message #2993 is a reply to message #2959] Thu, 28 December 2006 04:44 Go to previous messageGo to next message
Hi ,
thanks for reply.
i didn't create bpdm.ecore file manually , it is generating using EMF
ecore editor.
as you told , I tried to change bpdm(i.e URI) to a , but still it not
works.
as i told you <GraphicalElements> is a EObject reference which contain
Task type object . below i describe actual hierachy.
FlowObject
+Name :Estring
Activity -> FlowObject
Task -> Activity
Task extends Activity and , Activity extnds FlowObject.
that's why i given GraphicalElements of type Task. <GraphicalElements
xsi:type="a:Task">.
but it still give an error.
Re: [ATL] how to use xsi:type in atl input model file [message #3043 is a reply to message #2993] Thu, 28 December 2006 05:53 Go to previous message
Brajesh,
The use of a prefix "bpdm" for which there is no corresponding xmlns
declaration seems very odd and doesn't seem like something that EMF
would produce; I'd expect it to use "a" since that's the prefix that has
been declared. In any case, if EMF is failing to read a resource, it
will produce an exception that explains why (and you can look at
Resource.getErrors/getWarnings to see all the things that have gone
wrong while loading), so if there is a problem reading (perhaps even a
bug), there must be a more informative exception (pointing into the XMI
code) than the stack trace in the scaffolding code you've shown...
brajesh K. wrote:
> Hi ,
> thanks for reply.
> ecore editor. as you told , I tried to change bpdm(i.e URI) to a , but
> still it not works.
> FlowObject +Name :Estring
> Task -> Activity
> xsi:type="a:Task">. but it still give an error.
Previous Topic:problem at lanunching ATL
Next Topic:[ATL] Error when launching ATL programmatically
Current Time: Sat Jul 12 20:28:03 EDT 2025
Powered by FUDForum. Page generated in 0.05202 seconds
