| Need help on setting up to use Weblogic Connection Pool [message #337460] | Wed, 23 January 2008 19:00 |  |
| Eclipse User  |  |  |  |  | Originally posted by: selene.lo.infor.com
 I try to use the connection pool named "dataPool" I defined on Weblogic
 9.2 as the data source of the report. Here is what I have done:
 I updated the .rptdesign file as follow:
 <data-sources>
 <oda-data-source
 extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
 id="43">
 <property
 name="odaDriverClass">weblogic.jdbc.pool.Driver</property >
 <property name="odaURL">jdbc:weblogic:pool:dataPool</property>
 <property name="odaUser"></property>
 <encrypted-property name="odaPassword"></encrypted-property>
 </oda-data-source>
 </data-sources>
 I copied the weblogic.jar and xbean.jar from weblogic package into
 WEB-INF\platform\plugins\org.eclipse.birt.report.data.oda.jd bc_2.2.1.r22x_v20070919\drivers
 folder. When I tried to run the report, I ran into this error:
 SEVERE: Error happened while running the report.
 java.lang.NoClassDefFoundError
 at  sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
 Method)
 sun.reflect.NativeConstructorAccessorImpl.newInstance(Native Construct
 orAccessorImpl.java:39)
 sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingC
 onstructorAccessorImpl.java:27)
 at  java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
 at java.lang.Class.newInstance0(Class.java:350)
 at java.lang.Class.newInstance(Class.java:303)
 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.find Driver(JD
 BCDriverManager.java:631)
 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load AndRegist
 erDriver(JDBCDriverManager.java:731)
 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDB
 CDriverManager.java:192)
 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection
 (JDBCDriverManager.java:158)
 org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connect
 ion.java:158)
 org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java
 :115)
 org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.
 open(OdaConnection.java:235)
 org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnec
 tion(ConnectionManager.java:145)
 org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSo
 urce.java:134)
 org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java
 :121)
 org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource
 (DataSourceRuntime.java:214)
 org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryE
 xecutor.java:265)
 org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(Quer
 yExecutor.java:210)
 org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQue
 ry.java:500)
 org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(Pre
 paredDataSourceQuery.java:161)
 org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (Prepared
 OdaDSQuery.java:142)
 paredDataSourceQuery.java:141)
 org.eclipse.birt.report.data.adapter.impl.DataSetIterator.ex ecuteQuer
 y(DataSetIterator.java:175)
 org.eclipse.birt.report.data.adapter.impl.DataSetIterator.<init >(Data
 SetIterator.java:127)
 org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.popu
 lateDimension(DataRequestSessionImpl.java:833)
 lateDimensions(DataRequestSessionImpl.java:766)
 org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.crea
 teCube(DataRequestSessionImpl.java:594)
 org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.mate
 rializeCube(DataRequestSessionImpl.java:526)
 org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.prep
 are(DataRequestSessionImpl.java:888)
 are(DataRequestSessionImpl.java:467)
 org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doPrepar
 eQuery(DataGenerationEngine.java:94)
 org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.p repare(Ab
 stractDataEngine.java:138)
 org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(Report
 Executor.java:94)
 org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportEx
 ecutor.execute(WrappedReportExecutor.java:59)
 org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortEmitte
 rExecutor.execute(ReportEmitterExecutor.java:76)
 org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplciat
 eReportExecutor.execute(SuppressDuplciateReportExecutor.java :51)
 org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.bui
 ld(ReportDocumentBuilder.java:187)
 org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:22
 4)
 org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:89)
 org.eclipse.birt.report.service.ReportEngineService.runRepor t(Unknown
 Source)
 org.eclipse.birt.report.service.BirtViewerReportService.runR eport(Unk
 nown Source)
 org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHand
 ler.__execute(Unknown Source)
 org.eclipse.birt.report.service.actionhandler.BirtChangePara meterActi
 onHandler.runReport(Unknown Source)
 org.eclipse.birt.report.service.actionhandler.AbstractChange Parameter
 ActionHandler.__execute(Unknown Source)
 org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandl
 er.execute(Unknown Source)
 org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProc
 essor.__executeAction(Unknown Source)
 org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentPro
 cessor.executeAction(Unknown Source)
 org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.ha
 ndleChangeParameter(Unknown Source)
 sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
 java:39)
 sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
 sorImpl.java:25)
 cessor.process(Unknown Source)
 org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUp
 datedObjects(Unknown Source)
 java:39)
 sorImpl.java:25)
 org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.j
 ava:397)
 org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider
 java:186)
 org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:
 323)
 org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrateg
 y.java:32)
 at  org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
 at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
 org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453
 at  org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
 org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:69
 9)
 org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPo
 st(Unknown Source)
 at  javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
 org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBas
 e.java:327)
 at  javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
 weblogic.servlet.internal.StubSecurityHelper$ServletServiceA ction.run
 (StubSecurityHelper.java:223)
 weblogic.servlet.internal.StubSecurityHelper.invokeServlet(S tubSecuri
 tyHelper.java:125)
 weblogic.servlet.internal.ServletStubImpl.execute(ServletStu bImpl.jav
 a:283)
 weblogic.servlet.internal.TailFilter.doFilter(TailFilter.jav a:26)
 weblogic.servlet.internal.FilterChainImpl.doFilter(FilterCha inImpl.ja
 va:42)
 at  org.eclipse.birt.report.filter.ViewerFilter.doFilter(Unknown
 Source)
 va:42)
 weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionActio
 n.run(WebAppServletContext.java:3243)
 weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticate
 dSubject.java:321)
 weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:
 121)
 weblogic.servlet.internal.WebAppServletContext.securedExecut e(WebAppS
 ervletContext.java:2003)
 weblogic.servlet.internal.WebAppServletContext.execute(WebAp pServletC
 ontext.java:1909)
 weblogic.servlet.internal.ServletRequestImpl.run(ServletRequ estImpl.j
 ava:1359)
 at weblogic.work.ExecuteThread.execute(ExecuteThread.java:209)
 at weblogic.work.ExecuteThread.run(ExecuteThread.java:181)
 What am I missing? Can someone help?
 Selene
FUDForum. Page generated in 0.10109 seconds
