Re: compiler.exe -s0 for Windows [message #1829609 is a reply to message #1829580] |
Tue, 07 July 2020 15:15 |
Hi Olaf,
unfortunately we have encountered the same problem and we had to accept that we cannot produce the Windows build we have delivered to you so far;
However, there are alternatives we can offer that might be suitable for you
-Windows 10 (assuming you have Windows 10) provides nowadays an embedded Linux environment WSL (Windows Subsystem for Linux) that allows simple installation of one or several different Linux distros within Windows. Appropriate Titan Linux binaries can be easily installed into WSL; as you are using Titan for compilation only (not execution), this should be fairly straightforward and of course we are prepared to assist you with installation if needed.
The latest Titan binary (7.1.0) can be downloaded from
https://projects.eclipse.org/projects/tools.titan/downloads
for a number of Linux distros and can be used in WSL directly.
This workflow will permit you to keep almost the same environment,
namely notepad++ on Windows and Titan under WSL in a console window.
-in a longer-term perspective, we are working on completing a pure Java version of Titan that would automatically solve issues of portability to Windows ;
If you are interested in this , please give it a try; the core language is not fully covered yet, but we are not far from that.
Please let me know how we may help you with any of the above alternatives.
Best regards
Elemer
[Updated on: Tue, 07 July 2020 15:19] Report message to a moderator
FUDForum. Page generated in 0.04615 seconds
