Code signature error: could not load SWT library in OS X Catalina [message #1828594] |
Sun, 14 June 2020 05:11 |
Shaokai Lin Messages: 5 Registered: June 2020 |
Hi everyone,
I am trying to run an Xtend project from the Eclipse IDE but after I click Run As -> Eclipse Application, Eclipse outputs the error below:
(simplified path for readability)
java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: dlopen(/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib, 1): no suitable image found. Did find:
/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: code signature in (/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib) not valid for use in process using Library Validation: mapping process and mapped file (non-platform) have different Team IDs
/Users/.../.../.cp/libswt-cocoa-4932r18.jnilib: stat() failed with errno=316
no swt-cocoa in java.library.path: [/Users/xxx/Library/Java/Extensions, /Library/Java/Extensions, /Network/Library/Java/Extensions, /System/Library/Java/Extensions, /usr/lib/java, .]
/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib: dlopen(/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib, 1): no suitable image found. Did find:
/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib: code signature in (/Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa-4932r18.jnilib) not valid for use in process using Library Validation: mapping process and mapped file (non-platform) have different Team IDs
Can't load library: /Users/shaokai/.swt/lib/macosx/x86_64/libswt-cocoa.jnilib
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:342)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:256)
at org.eclipse.swt.internal.C.<clinit>(C.java:19)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:107)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:760)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:166)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:180)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
I suspect this is an OS X Catalina problem, as I've heard that it enforces a stricter requirement on code signatures in this new version.
Any thoughts on resolving this issue? Thanks very much.
Shaokai
FUDForum. Page generated in 0.03052 seconds
