Home » Eclipse Projects » Eclipse Platform » Re: Confirm view closing.
Re: Confirm view closing. [message #337057] Sat, 25 July 2009 04:31 Go to next message
Forwarding to eclipse.platform.
> A user clicks the small x in a view to close that view. What's the
> correct way to intercept this, so that I can ask for a confirmation to
> close the view etc.
I should probably add that the view I'm talking about is provided by my
plug-in so I'm able to modify the view implementation itself should that
be neccessary.
Thanks again,
Felix
Re: Confirm view closing. [message #337087 is a reply to message #337057] Mon, 27 July 2009 10:45 Go to previous messageGo to next message
>> close the view etc.
> be neccessary.
> Thanks again,
> Felix
When you own the perspective you can mark a view as not closable. But
when your view is brought up in a perspective not owned by you then I'm
not aware of a way to tell Eclipse to mark it not closable.
It is possible to listen for part events like close by implementing
IPartListener and calling getPartService().addPartListener().
Re: Confirm view closing. [message #468102 is a reply to message #337057] Tue, 04 August 2009 03:35 Go to previous messageGo to next message
>> to close the view etc.
See org.eclipse.ui.ISaveablePart2.promptToSaveOnClose()
Dani
> my plug-in so I'm able to modify the view implementation itself should
> that be neccessary.
> Thanks again,
> Felix
Re: Confirm view closing. [message #468267 is a reply to message #468102] Tue, 04 August 2009 14:36 Go to previous message
>>> close the view etc.
> Dani
Good solution, thanks Dani.
Previous Topic:Viewpart vs. Editorpart, proxy Editorpart, common Eclipse design question
Next Topic:thread from ant build does not exit
Current Time: Thu Jul 17 19:40:32 EDT 2025
Powered by FUDForum. Page generated in 0.05449 seconds
