Re: Double Click tool not working on layer [message #1826567 is a reply to message #1824505] |
Mon, 27 April 2020 08:31 |
Indeed, this looks like a limitation of the double click tool, I see no reason a mapping couldn't be associated with several double click tool. You can create a new bugzilla and file it as an enhancement. However, I can't tell you when we will work on it.
I think the easiest solution to bypass the issue, is to have a single double click tool in the default layer. In the tool, you have as many "if" model operation has you wanted double click tools. In the "if" you use the variable "elementView" (probably easier with a java service) in order to check if the layer is active or not.
Otherwise, you can have a custom style [1], implement your own Edit Part that will have a listener that reacts on double click.
Steve
[1] https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom_style.html
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.04149 seconds
