How to Add menu contribution when an specific editor is active - using org.eclipse.ui.menus [message #337029] |
Wed, 22 July 2009 05:46  |
Originally posted by: lennart.x.akobson.analogix.com
Hi all,
I need to add a sub menu into the existing File menu in the Main menu when
when at least one instance of my editor is open. I have
found that should be possible to do programmaticly using the
contributorClass in the org.eclipse.ui.edtors extension point schema.
But I have also found that org.eclipse.ui.menus can do sort of this, but
I',m not sure how to set this up.
The scenario is as follows: When an instance of a specic editor is active
there should be an additional sub menu available in
the File Menu meny. This sub menu should have a couple of menu entries.
Can anyone share how to do this?
BR
L
FUDForum. Page generated in 0.45784 seconds
