Home » Eclipse Projects » Eclipse Platform » expression-based activity using <test property="org.eclipse.core.runtime.product"> :
expression-based activity using <test property="org.eclipse.core.runtime.product"> : [message #336963] Thu, 16 July 2009 12:02 Go to next message
Targeting 3.4.2,
I have bound some UI contributions (wizards) to an expression-based
activity using a definition reference in its <enabledWhen> :
<extension point="org.eclipse.ui.activities">
<activity id="foo.activity.definitions" name="foo">
<enabledWhen>
<reference definitionId="fooDefinitionsAccessible"/>
</enabledWhen>
</activity>
<activityPatternBinding>...
</activityPatternBinding>
</extension>
<extension point="org.eclipse.ui.newWizards">
It all works perfectly if I use systemTest in the definition, e.g.
<extension point="org.eclipse.core.expressions.definitions">
<definition id="fooDefinitionsAccessible">
<systemTest property="java.vendor" value="IBM Corporation" />
</definition>
</extension>
However I need the expression to check for product id (or even better
for isBundleInstalled)
as soon as I change the above to
args="foo.product"
forcePluginActivation="true" />
</definition>
</extension>
Then my activity is always disabled
Adding a breakpoint to
org.eclipse.core.internal.expressions.propertytester.Platfor mPropertyTester
and launching in debug ... execution seem to never get there.
I hope I'm just using the wrong syntax ?
Re: expression-based activity using <test property="org.eclipse.core.runtime.product"&g [message #336967 is a reply to message #336963] Thu, 16 July 2009 16:19 Go to previous message
Solved !
<with variable="org.eclipse.core.runtime.Platform">
value="fooproduct"
</with>
</definition>
</extension>
<activity
id="foodefinitions"
name="foo">
<enabledWhen>
</enabledWhen>
</activity>
activityId="foodefinitions"
pattern="...">
</extension>
Edoardo Comar wrote:
> Targeting 3.4.2,
> <enabledWhen>
> </enabledWhen>
> </activity>
> </extension>
> </definition>
> </extension>
> args="foo.product"
> </definition>
> </extension>
Previous Topic:Master configuration initialization
Next Topic:History of console(s)
Current Time: Thu Jul 17 22:00:45 EDT 2025
Powered by FUDForum. Page generated in 0.14556 seconds
