| Linked source directory not recognized as cvs folder [message #336880] |
Thu, 09 July 2009 01:58  |
I've got a problem with a linked source dir, which is not recognized as a
cvs directory.
My (checked out) cvs structure is like this:
my_sandbox(CVS-Root)
|-- Projects
| |-- ProjectA
| | |-- .project + .classpath
| | |-- ProjectA_Documentation
| |-- ProjectB
| |-- ProjectB_Documentation
|-- src
|-- org....
So I have the sources for all projects within the directory "src", all
other files for a project are within a parallel project directory (let's
say "ProjectA"). Here are the build files plus .project/.classpath.
When working with ProjectA, the Java sources are a linked resource named
"src",
where the link path is ...my_sandbox/src with a couple of
includes/excludes.
Works fine except that this linked src directory within my project has no
"cvs nature" -- it does not recognize to be a cvs managed directory.
So I can't use eclipse's cvs-Plugin for my sources this way.
My .project looks like this:
<projectDescription>
<name>ProjectA</name>
<linkedResources>
<link>
<name>src</name>
<type>2</type>
<location>D:/Dev/my_sandbox/src</location>
</link>
</linkedResources>
</projectDescription>
As usual, the directory structure is "grown". So reorganizing the whole
cvs structure is not an option. All I need is eclipse to recognize a
linked folder as being cvs managed, such that I have full access to all
cvs commands for my sources from eclipse.
Thanks in advance,
Holger
| Re: Linked source directory not recognized as cvs folder [message #336883 is a reply to message #336880] |
Thu, 09 July 2009 06:50  |
Holger wrote:
> as a cvs directory.
> |-- Projects
> | |-- ProjectA
> | |-- ProjectB
> |-- src
> |-- org....
> (let's say "ProjectA"). Here are the build files plus
> named "src",
> includes/excludes.
> no "cvs nature" -- it does not recognize to be a cvs managed
> directory. So I can't use eclipse's cvs-Plugin for my sources this way.
Right, see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=39612.
Dani
> <linkedResources>
> <link>
> <name>src</name>
> <type>2</type>
> </link>
> </linkedResources>
> whole cvs structure is not an option. All I need is eclipse to
> recognize a linked folder as being cvs managed, such that I have full
> access to all cvs commands for my sources from eclipse.
> Thanks in advance,
> Holger
FUDForum. Page generated in 0.03897 seconds
