Home » Eclipse Projects » Eclipse Platform » Where is the eclipse.buildId property set?
Where is the eclipse.buildId property set? [message #336870] Wed, 08 July 2009 13:13 Go to next message
This property is used in the splash screen and in the About Dialog. I
couldn't find the place where it is set. Any clues?
- Prakash
http://blog.eclipse-tips.com
Re: Where is the eclipse.buildId property set? [message #336874 is a reply to message #336870] Wed, 08 July 2009 13:53 Go to previous messageGo to next message
> - Prakash
I found it in configuration/config.ini in a stock Eclipse platform
download.
Re: Where is the eclipse.buildId property set? [message #336875 is a reply to message #336874] Wed, 08 July 2009 14:09 Go to previous messageGo to next message
> download.
Yes, Its taken from here and loaded into System properties. I'm looking
for the code which does this. Could it be p2?
- Prakash
Re: Where is the eclipse.buildId property set? [message #336897 is a reply to message #336875] Fri, 10 July 2009 11:44 Go to previous message
p2 doesn't know what that property is, but it is getting set by p2
because the SDK defines it in the metadata.
The SDK is build using a .product file which contains
<configurations>
<property name="eclipse.buildId" value="@qualifier@"/>
</configurations>
Where the @qualifier@ gets replaced at build time. This results in the
property being generated into the p2 metadata and p2 writing it in the
config.ini at install time.
-Andrew
>> download.
> looking for the code which does this. Could it be p2?
> - Prakash
Previous Topic:How to extend an update site reliably and easily ?
Next Topic:File not found after trying to get Eclipse language pack
Current Time: Fri Jul 18 08:18:10 EDT 2025
Powered by FUDForum. Page generated in 0.10535 seconds
