Home » Eclipse Projects » Eclipse Platform » When is the feature "image" property used?
When is the feature "image" property used? [message #336850] Wed, 08 July 2009 03:16 Go to next message
I wonder when the "image" attribute you can specify on the feature
element of a feature.xml is used? Its not used in the about dialog.
Maybe in the update manager UI?
Re: When is the feature "image" property used? [message #336851 is a reply to message #336850] Wed, 08 July 2009 03:29 Go to previous messageGo to next message
I think its used in the About box also.
- Prakash
http://blog.eclipse-tips.com
Re: When is the feature "image" property used? [message #336852 is a reply to message #336851] Wed, 08 July 2009 03:38 Go to previous message
Wow, that was a quick response Prakash :)
But unfortunately its not used in the About box. Just tried it out.
Included the image into the build.properties but it does not show up in
the about dialog. And the way the about dialogs feature buttons are
build the attribute is never even read.
Phil
Previous Topic:Display an XML file in an XML editor, not in the default text editor
Next Topic:Conflicting scheduling rules
Current Time: Sat Nov 08 09:30:10 EST 2025
Powered by FUDForum. Page generated in 0.23973 seconds
