Home » Eclipse Projects » Eclipse Platform » standard button width in wizards and dialogs?
standard button width in wizards and dialogs? [message #336816] Sat, 04 July 2009 09:12 Go to next message
when using jdt I noticed that buttons have a common width, which is
broader than the minimum width would be.
Is there a default width value for buttons in eclipse or is that jdt
specific?
And what value would that be?
And finally (although more SWT related) would I get this by setting the
width hint of my layoutData objects?
regards
Christoph
Re: standard button width in wizards and dialogs? [message #336836 is a reply to message #336816] Mon, 06 July 2009 11:14 Go to previous message
See org.eclipse.jface.dialogs.DialogPage.setButtonLayoutData(But ton),
org.eclipse.jface.dialogs.Dialog.createButton(Composite, int, String,
boolean), and
org.eclipse.jface.dialogs.Dialog.setButtonLayoutData(Button) for where
eclipse sets the widths for most wizard pages and dialogs.
PW
Paul Webster
Previous Topic:remove toolbar/menu entries contributed by other plugins
Next Topic:Compile & Build Eclipse from Sourcecode does NOT work!!
Current Time: Fri Nov 14 08:43:57 EST 2025
Powered by FUDForum. Page generated in 0.04892 seconds
