Home » Eclipse Projects » Eclipse Platform » remove toolbar/menu entries contributed by other plugins
remove toolbar/menu entries contributed by other plugins [message #336810] Fri, 03 July 2009 11:27 Go to next message
I've got a custom RCP application here and am looking for a way to remove
the toolbar and menu's contributed by the org.eclipse.debug plugin without
changing the plugins configuration?
I've found an older thread in which its suggested to use activities, but
that only seemed to work when loading the jdt plugin (IIRC). Also that
thread is from 2005 and I hope things improved by now in that area?
Andreas
Re: remove toolbar/menu entries contributed by other plugins [message #336835 is a reply to message #336810] Mon, 06 July 2009 11:12 Go to previous message
You still use activities in 3.5, and they're supported by org.eclipse.ui
(part of RCP).
Starting point:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench_advext_activities.htm
I'd also check if there are any http://www.eclipse.org/articles/
PW
Paul Webster
Previous Topic:Tracking cursor / current line in StyledText
Next Topic:standard button width in wizards and dialogs?
Current Time: Sat Aug 30 22:00:08 EDT 2025
Powered by FUDForum. Page generated in 0.02992 seconds
