help tying my ODA into the report designer UI [message #34190] |
Wed, 04 May 2005 13:07  |
I'm working from 5/4/2005 source
In theory, if I write and register an ODA, the Report Designer should
work with it? I have registered wizard pages for my ODA Data Source, and
Data Set and they come up when working in the Report designer
however.... I'm using the flat file example, as reference to how to wire
up to the Report designer framework, but this may be a bad idea as the
Flat file Example Doesn't seem to work beyond a minimal level, I can't
get a Data set to show up, when I click finish on the flat file data set
wizaard nor get the report to render, I get an error in multiple places:
org.eclipse.birt.data.engine.core.DataException occurred
Error Code:DATA_EXCEPTION_odaconsumer.CannotPrepareStatement
Error Message:Cannot prepare the query (select * from mycsv) for the
data set type (FlatFileSelectDataSet).
Source data error
Anyone get this to work, or is it just broke at the moment?
FUDForum. Page generated in 0.13938 seconds
