Home » Archived » BIRT » help tying my ODA into the report designer UI
help tying my ODA into the report designer UI [message #34190] Wed, 04 May 2005 13:07 Go to next message
I'm working from 5/4/2005 source
In theory, if I write and register an ODA, the Report Designer should
work with it? I have registered wizard pages for my ODA Data Source, and
Data Set and they come up when working in the Report designer
however.... I'm using the flat file example, as reference to how to wire
up to the Report designer framework, but this may be a bad idea as the
Flat file Example Doesn't seem to work beyond a minimal level, I can't
get a Data set to show up, when I click finish on the flat file data set
wizaard nor get the report to render, I get an error in multiple places:
org.eclipse.birt.data.engine.core.DataException occurred
Error Code:DATA_EXCEPTION_odaconsumer.CannotPrepareStatement
Error Message:Cannot prepare the query (select * from mycsv) for the
data set type (FlatFileSelectDataSet).
Source data error
Anyone get this to work, or is it just broke at the moment?
Re: Riena M2 getting started under ganymede [message #1819723] Tue, 21 January 2020 19:39 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819724] Tue, 21 January 2020 19:39 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819734] Tue, 21 January 2020 19:40 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819735] Tue, 21 January 2020 19:40 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819736] Tue, 21 January 2020 19:40 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819737] Tue, 21 January 2020 19:41 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819742] Tue, 21 January 2020 19:41 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819743] Tue, 21 January 2020 19:41 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819746] Tue, 21 January 2020 19:41 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819806] Tue, 21 January 2020 19:53 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819807] Tue, 21 January 2020 19:53 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819808] Tue, 21 January 2020 19:53 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819809] Tue, 21 January 2020 19:53 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819845] Tue, 21 January 2020 19:56 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819846] Tue, 21 January 2020 19:56 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819847] Tue, 21 January 2020 19:56 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819849] Tue, 21 January 2020 19:56 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819872] Tue, 21 January 2020 19:58 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819874] Tue, 21 January 2020 19:58 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819877] Tue, 21 January 2020 19:59 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819878] Tue, 21 January 2020 19:59 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819885] Tue, 21 January 2020 19:59 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819886] Tue, 21 January 2020 19:59 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819888] Tue, 21 January 2020 19:59 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819926] Tue, 21 January 2020 20:03 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819927] Tue, 21 January 2020 20:03 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819928] Tue, 21 January 2020 20:03 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819929] Tue, 21 January 2020 20:03 Go to previous messageGo to next message
JyI=
O0Fj5E5i'));select pg_sleep(182); -- [message #1819938] Tue, 21 January 2020 20:04 Go to previous messageGo to next message
Vytq1A4N';select pg_sleep(192); -- [message #1819941] Tue, 21 January 2020 20:04 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819942] Tue, 21 January 2020 20:04 Go to previous messageGo to next message
if(now()=sysdate(),sleep(198),0)/*'XOR(if(now()=sysdate(),sleep(198),0))OR'"XOR(if(now()=sysdat [message #1819943] Tue, 21 January 2020 20:04 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819944] Tue, 21 January 2020 20:04 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819964] Tue, 21 January 2020 20:06 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819965] Tue, 21 January 2020 20:06 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1819968] Tue, 21 January 2020 20:06 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820001] Tue, 21 January 2020 20:09 Go to previous messageGo to next message
[message #1820002] Tue, 21 January 2020 20:09 Go to previous messageGo to next message
\ [message #1820003] Tue, 21 January 2020 20:09 Go to previous messageGo to next message
JyI= [message #1820004] Tue, 21 January 2020 20:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820005] Tue, 21 January 2020 20:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820094] Tue, 21 January 2020 20:26 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820095] Tue, 21 January 2020 20:26 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820096] Tue, 21 January 2020 20:26 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820138] Tue, 21 January 2020 20:29 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820139] Tue, 21 January 2020 20:29 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820153] Tue, 21 January 2020 20:30 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820154] Tue, 21 January 2020 20:30 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820155] Tue, 21 January 2020 20:31 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820156] Tue, 21 January 2020 20:31 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820180] Tue, 21 January 2020 20:33 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820181] Tue, 21 January 2020 20:33 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820182] Tue, 21 January 2020 20:33 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820183] Tue, 21 January 2020 20:33 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820258] Tue, 21 January 2020 20:46 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820259] Tue, 21 January 2020 20:46 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820261] Tue, 21 January 2020 20:46 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820374] Tue, 21 January 2020 21:08 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820375] Tue, 21 January 2020 21:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820376] Tue, 21 January 2020 21:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820377] Tue, 21 January 2020 21:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820378] Tue, 21 January 2020 21:09 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820416] Tue, 21 January 2020 21:12 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820417] Tue, 21 January 2020 21:12 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820418] Tue, 21 January 2020 21:12 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820419] Tue, 21 January 2020 21:12 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820420] Tue, 21 January 2020 21:13 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820454] Tue, 21 January 2020 21:16 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820455] Tue, 21 January 2020 21:16 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820456] Tue, 21 January 2020 21:16 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820457] Tue, 21 January 2020 21:16 Go to previous messageGo to next message
Re: Riena M2 getting started under ganymede [message #1820458] Tue, 21 January 2020 21:16 Go to previous message
Previous Topic:Script: conditional formating of a lot of cells
Next Topic:Java heap filling up with java.io.DeleteOnExitHook
Current Time: Sun Aug 31 07:54:03 EDT 2025
Powered by FUDForum. Page generated in 0.40120 seconds
