Home » Eclipse Projects » Eclipse Platform » WHere to download releng basebuilder for 3.4.2
WHere to download releng basebuilder for 3.4.2 [message #336654] Fri, 26 June 2009 02:19 Go to next message
Hello all,
I am trying to find a binary download location for the releng basebuilder
for eclipse 3.4.2 but my search had no success!
I can get the sources from the svn but don't want to build it on my own.
Is there a bin download location where I can get it?
Greets Marko
Re: WHere to download releng basebuilder for 3.4.2 [message #336673 is a reply to message #336654] Fri, 26 June 2009 13:05 Go to previous message
The basebuilder is already binary.
You can get it export it from CVS using:
cvs -d :pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse \
ex -r $basebuilderBranch org.eclipse.releng.basebuilder
basebuilderBranch should equal the tag of the builder you want. You
could use R3_4 or R3_4_1 as the tag to load.
PW
Paul Webster
Previous Topic:Enable/Disable plugin.xml generated menus
Next Topic:Same installed plug-ins for all the team
Current Time: Tue Sep 09 12:26:14 EDT 2025
Powered by FUDForum. Page generated in 0.07833 seconds
