Home » Eclipse Projects » Eclipse Platform » Galileo Release - ClearCase-Plugin is not correct
Galileo Release - ClearCase-Plugin is not correct [message #336624] Thu, 25 June 2009 09:57 Go to next message
Hi there,
please let me know if this is not the proper ng for this topic.
We use ClearCase for SCM with the plugin from [1]. This plugin works
nice with RC3 and RC4 of Galileo. But now with the released version of
Galileo it doesn't work correct. On the list of installed plugins it is
shown and I can't find any error. But it is not visible on the GUI which
means that there is no toolbar and even the context menu "Team" has only
the two default entries.
Strange is, that it seems to work. So I can see the underlays under the
icons in front of the files on a project, which tells that this file is
under source control or not. Additionally the name of the ClearCase-View
is displayed correctly. This tells me that the connection to ClearCase
is successfully done.
If an opened file is edited, the ClearCase checkout dialog pops up and
the proper symbol for a checked out file appears on the icon of this
file. But with an empty Team context menu and no toolbar I can't checkin
the files or do all the other neccessary stuff like version tree, merge
and so on.
Any suggestions? Should I file a bug report?
[1]
http://www.ibm.com/developerworks/rational/library/content/0 3July/2500/2834/ClearCase/clearcase_plugins.html#download
Yves
Re: Galileo Release - ClearCase-Plugin is not correct [message #336627 is a reply to message #336624] Thu, 25 June 2009 10:27 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Which version are you using?
If it is the latest 7.0.0 version for 3.4, make sure that you follow the
directions for Activating the ClearCase SCM Adapter in the Tasks section of
the Rational ClearCase SCM Adapter help document. You need to use the
Eclipse Capabilities feature to active the latest version.
"Yves Schumann" <starwarsfan@bluewin.ch> wrote in message
news:h1vvp4$fnd$1@build.eclipse.org...
> Hi there,
> and so on.
> [1]
> Yves
Re: Galileo Release - ClearCase-Plugin is not correct [message #336629 is a reply to message #336627] Thu, 25 June 2009 10:43 Go to previous message
Hi Dave
We use the version from the website from [1] which is
"com.rational.clearcase.win32-20081031A.zip". Is there a newer version
somewhere else?
You made my day! That's it, thank you very much. <thumbs-up/>
Yves
"Hamburger! Der Grundstein eines jeden nahrhaften Frühstücks!" -- Pulp
Fiction
Previous Topic:How might one reduce the tooltip delay on Mac OS X?
Next Topic:Adding markers during project refresh
Current Time: Thu Jul 24 01:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.03519 seconds
