Home » Eclipse Projects » Eclipse Platform » Why some items aren't uninstallable with galileo?
Why some items aren't uninstallable with galileo? [message #336601] Wed, 24 June 2009 16:49 Go to next message
I have downloaded Galileo modeling package containing UML2Tools project,
I would like to uninstall UML2Tools from "Eclipse Installation
Details" dialog but when select "UML2Tools" item "Uninstall..." button
is disabled.
Why?
Thanks.
Re: Why some items aren't uninstallable with galileo? [message #336631 is a reply to message #336601] Thu, 25 June 2009 11:08 Go to previous messageGo to next message
There are two kinds of things that are installed into Eclipse.
1) Things that are explicitly installed because the user asked for it,
or the package producer installed it.
2) Everything else that is required by the things in (1).
You can't uninstall the things in (2) because they are required by the
things in (1). To get rid of them, you would need in uninstall the
thing in (1) that required it.
In Help -> About Eclipse -> Installation Details -> Installed Software,
the things at the root of the tree are explicitly installed (1).
Everything under the roots, are the things that are required (2).
For the modeling package, there is only 1 thing installed: "Eclipse
Modeling Tools (epp.package.modeling).
If you want an install without the UML2Tools, you would need to start
with an install that uses a smaller root, and then add what you want on
top of that. (ie start with Eclipse Classic and build up from there).
-Andrew
Esteban DUGUEPEROUX wrote:
> I would like to uninstall UML2Tools from "Eclipse Installation Details"
> dialog but when select "UML2Tools" item "Uninstall..." button is disabled.
> Why?
> Thanks.
Re: Why some items aren't uninstallable with galileo? [message #336653 is a reply to message #336631] Fri, 26 June 2009 02:03 Go to previous message
Thanks Andrew.
Previous Topic:Create Markers not on IResource/IFile
Next Topic:Problem with Galileo
Current Time: Sat Nov 08 01:51:53 EST 2025
Powered by FUDForum. Page generated in 0.03454 seconds
