Home » Eclipse Projects » Eclipse Platform » P2 - "Install New Software" behind company proxy
P2 - "Install New Software" behind company proxy [message #336597] Wed, 24 June 2009 13:33 Go to next message
First let me congratulate you for the galileo release.. one love...
Today we ( 14 developers of a german car manufactory ) run into a very
strange problem with the p2 update manager. We can not connect to a
eclipse update site
- even not a to galileos own.
Every attempt ends with something like this :
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception:
Unable to read repository at
http://download.eclipse.org/tools/mylyn/update/e3.4/content. xml.
org.eclipse.equinox.internal.p2.metadata.repository.CacheMan ager.createCache(CacheManager.java:179)
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleM etadataRepositoryFactory.java:60)
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.validateAndLoad(Simp leMetadataRepositoryFactory.java:99)
Caused by: java.net.SocketException: Socket is closed
at java.net.Socket.setTcpNoDelay(Socket.java:825)
org.eclipse.ecf.provider.filetransfer.events.socket.Abstract SocketWrapper.setTcpNoDelay(AbstractSocketWrapper.java:187)
org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:721)
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1361)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
the think is that we sit behind several proxies when at work.
Even when the proxy settings are set correctly - we could connect to our
bugzilla repository and even when trying galileos Test Connection feature
it shows that the requested URL is available.
Some month ago we had a "similar" problem with ivy RC1 when trying to
resolve jars from ibiblio. We found out that it was a http HEAD request
that that was causing the trouble. For some reason the proxies couldn't
handle it correctly so the ivy guys added a configurable option to always
use a GET request.
Before we start looking into it deeper it would be great to know if
somebody has a explanation for this behaviour.
Now from my home machines everything works fantastic like always.
Ivan
Re: P2 - "Install New Software" behind company proxy [message #336677 is a reply to message #336597] Fri, 26 June 2009 13:46 Go to previous messageGo to next message
I'm having the same problem, this is the stack trace the error log gives
me:
http://download.eclipse.org/eclipse/updates/3.5/content.xml.
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.load(SimpleMetadataR epositoryFactory.java:87)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :54)
org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:669)
org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:617)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
org.apache.commons.httpclient.HttpParser.readRawLine(HttpPar ser.java:78)
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser .java:106)
org.apache.commons.httpclient.HttpConnection.readLine(HttpCo nnection.java:1116)
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnect ionManager.java:1413)
org.apache.commons.httpclient.HttpMethodBase.readStatusLine( HttpMethodBase.java:1973)
org.apache.commons.httpclient.HttpMethodBase.readResponse(Ht tpMethodBase.java:1735)
org.apache.commons.httpclient.HttpMethodBase.execute(HttpMet hodBase.java:1098)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:398)
org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:346)
org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientF ileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java :188)
org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSys temBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:7 1)
... 1 more
I tried changing the proxy settings but it still doesn't work, but when I
use Eclipse 3.4 it accesses the update sites correctly (including
Galileo's site).
Re: P2 - "Install New Software" behind company proxy [message #336683 is a reply to message #336677] Fri, 26 June 2009 14:47 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=281472
Paul Webster
Re: P2 - "Install New Software" behind company proxy [message #629187 is a reply to message #336683] Mon, 27 September 2010 08:58 Go to previous message
I'm facing some problems with our application, not sure if its something todo with the Proxy.
I'm getting Nullpointer exception at RepositoryTransport.download(RepositoryTransport.java:75) if I point to a remote repository. It works fine with local repository in the build directory. I have created the following bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=323149. Please let me know if anyone has a solution for this.
Previous Topic:Job not guaranteed to be scheduled ? eg @startup
Next Topic:Disable automatic proxy detection
Current Time: Tue Nov 04 15:46:55 EST 2025
Powered by FUDForum. Page generated in 0.03998 seconds
