Home » Eclipse Projects » Eclipse Platform » Delta pack not working in 3.5
Delta pack not working in 3.5 [message #336587] Wed, 24 June 2009 11:32 Go to next message
Originally posted by: phillipus.nowhere.net
Unzip the 3.5 Delta pack onto 3.5 installation.
No go. It doesn't show up.
What happened?
Re: Delta pack not working in 3.5 [message #336589 is a reply to message #336587] Wed, 24 June 2009 11:42 Go to previous messageGo to next message
> What happened?
OK, I think what's changed in 3.5 is that you can no longer unzip the
Delta pack over your Eclipse installation and it work. I've always done
this before in 3.3 and 3.2 (that's why it's a Delta pack, right?). Unzip
it into a separate folder and then add that to your PDE target setup.
Re: Delta pack not working in 3.5 [message #336590 is a reply to message #336589] Wed, 24 June 2009 11:51 Go to previous messageGo to next message
IMHO it was never meant to be unzipped above the installation but to use
in your PDE-Target. Your eclipse installation doesn't need the
additional fragments you get with the Delta-Pack because it's only
purpose is to run the current Eclipse-Instance you use for editing.
PDE by default points to the Eclipse-Installation as the target but
that's simply to help people who only do Eclipse-Plugin development to
install a secondary target because they rarely need to export for a
specific platform.
Tom
>> What happened?
Re: Delta pack not working in 3.5 [message #336591 is a reply to message #336590] Wed, 24 June 2009 11:55 Go to previous messageGo to next message
Tom Schindl wrote:
> specific platform.
> Tom
>>> What happened?
True, true, true. :-) It always worked though.
Re: Delta pack not working in 3.5 [message #336594 is a reply to message #336591] Wed, 24 June 2009 13:25 Go to previous messageGo to next message
Phillipus wrote:
> Tom Schindl wrote:
>> specific platform.
>> Tom
>>>> What happened?
It always used to work in 3.3 and earlier because the
org.eclipse.update.configurator was promiscuous. All bundles/fragments
there were found were installed regardless whether or not they would
actually work.
Now, with dropins, things are only going to get installed if they will
actually be resolvable in the running instance. In the case of the
deltapack, the majority of the fragments will not be resolvable because
they are the wrong platform. This was the source of the "Build target
based on the target's installed plug-ins" preference that needed to be
unchecked in 3.4
To make matters worse, there is a problem with the new publisher stuff
that creates metadata for things in the dropins folder. It screws up on
the equinox.executable feature (bug 278086).
Re: Delta pack not working in 3.5 [message #336596 is a reply to message #336594] Wed, 24 June 2009 13:28 Go to previous message
Andrew Niefer wrote:
> Phillipus wrote:
>> Tom Schindl wrote:
>>> Hi,
>>> specific platform.
>>> Tom
>>>>> What happened?
>>>> Unzip
> actually work.
> unchecked in 3.4
Thanks for the info!
Previous Topic:Galileo - "dropins" folder not working?
Next Topic:Eclipse 3.x for AIX 5.3
Current Time: Sat Sep 27 11:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.03232 seconds
