Re: Galileo - "dropins" folder not working? [message #336585 is a reply to message #336584] |
Wed, 24 June 2009 11:19   |
Why are you installing the delta pack into your eclipse installation?
You should create your own target and point PDE to it instead of using
the running Eclipse-Instance as the target.
Tom
Phillipus schrieb:
> Phillipus wrote:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Ed Merks wrote:
>>>>> Phillipus,
>>>>> I'd try running with -clean -debug and looking carefully at what's
>>>>> in the Error log. The -debug flag will produce more detailed
>>>>> messages about why something might fail to activate, i.e.,
>>>>> unsatisfied range constraints on bundle dependencies...
>>>>> Phillipus wrote:
>>>>>> Just got Eclipse 3.5. Put all my plug-ins in the "dropins" folder
>>>>>> and they don't show up. No way no how.
>>>>>> Am I missing something?
>>>> Ed, I found out what it is. It's an issue with installing the Delta
>>>> pack.
>>>> On Windows:
>>>> 1. Install a clean Eclipse 3.5
>>>> 2. Unzip the Delta pack over it.
>>>> 3. Put some plug-ins in the dropins folder
>>>> Result - they don't show up in Eclipse.
>>>> Don't install the Delta pack and it's fine.
>>>> I'm sure we had this bug in an earlier version of Eclipse.
>>>> Phillipus
>>> Bugbased - https://bugs.eclipse.org/bugs/show_bug.cgi?id=281353
>> In fact, things are worse than that - installing the Delta pack means
>> that no new plug-ins show up at all, even if they are in the normal
>> "plugins" folder!
> Er, even worser....The Delta pack doesn't show up at all, I think it's
> screwed. That kind of means no RCP development in 3.5. Ho hum.
Re: Galileo - "dropins" folder not working? [message #336586 is a reply to message #336585] |
Wed, 24 June 2009 11:30   |
Originally posted by: phillipus.nowhere.net
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Why? Because that's what I've always done. Target is the same as host.
That's what it's intended for. That's why it's a Delta pack.
Re: Galileo - "dropins" folder not working? [message #336588 is a reply to message #336585] |
Wed, 24 June 2009 11:39   |
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Mind you, doing that fixes the problem. Perhaps in 3.5 the Delta pack is
not meant to be installed over the running installation.
Re: Galileo - "dropins" folder not working? [message #336595 is a reply to message #336593] |
Wed, 24 June 2009 13:27  |
>>>>> "plugins" folder!
>> is not meant to be installed over the running installation.
> This will likely have to do with problems generating metadata on the
> org.eclipse.equinox.executable feature. See bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=248578
> The best way to install the delta pack is to extract it to its own
> directory and then add it to your target platform by editing the Active
> Target and adding the deltapack/eclipse directory.
Thanks for the info!
FUDForum. Page generated in 0.08351 seconds
