Home » Newcomers » Newcomers » newbie question about Eclipse for Java
newbie question about Eclipse for Java [message #34174] Mon, 14 March 2005 16:25 Go to next message
Originally posted by: tmm.blah.com
Hi.
I'm a C++ developer, trying to use Java for the 1st time. I tried
NetBeans and didn't like it so I tried eclipse and had a better
experience. I have a couple of questions about using Eclipse for Java.
Is this the right place?
My questions:
- How do I go into 'full-screen' mode?
- How do I make the status bar go away?
- Where do I find the eclipse user settings: the ones that are not
specific to the computer and can be copied to another installation of
eclipse. I want to try to keep the eclipses on my notebook and my
desktop synced. Are these in the .metadata folder tree?
- I have a java project for which I can't figure out where the
executable is. It's not in the project's folder tree. I can run the
program from within eclipse and it works fine, but where might that jar
file be?
thanks,
Tom.
Re: newbie question about Eclipse for Java [message #34343 is a reply to message #34174] Mon, 14 March 2005 20:51 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
See responses inline with questions.
Tom wrote:
> Hi.
> My questions:
The closest you're going to get is by double clicking the title tab of
any currently selected editor or view.
Don't think that's possible. Or at least easily accomplished from a
user perspective.
Most of the user settings are stored in the .metadata directory.
However a better way to share preferences is to export them as a file by
opening the Preferences dialog and hitting the Export button at the bottom.
> file be?
Java binaries do not have to be packaged in a jar in order to be
executable... simply running the .class file that has the main() method
is the basic way of executing a Java program. E.g. java MyClass (in the
directory where MyClass.class resides) If you wish to package your
program in a jar, see the Jar file Export wizard (File->Export... and
choose Jar file)
Hope this helps,
- Jeff
Re: newbie question about Eclipse for Java [message #34480 is a reply to message #34343] Mon, 14 March 2005 22:52 Go to previous messageGo to next message
> Tom wrote:
>> Hi.
>> My questions:
> user perspective.
> Most of the user settings are stored in the .metadata directory. However
> a better way to share preferences is to export them as a file by opening
Won't that just cover the preferences?
I want to get things like the 'run configurations' too. Or are those
stored in the project files?
>> jar file be?
> choose Jar file)
Ah, that explains my confusion.
Thanks for the info,
Tom.
> Hope this helps,
> - Jeff
Re: newbie question about Eclipse for Java [message #34853 is a reply to message #34480] Tue, 15 March 2005 10:12 Go to previous message
Originally posted by: eclipse.rizzoweb.com
>> by opening the Preferences dialog and hitting the Export button at the
>> bottom.
Launch Configurations can be stored in the project directory. If you're
editing a launch config, select the Common tab and you can make it a
"Shared" config and choose a location in your workspace to store it.
I usually create a .eclipse directory that gets checked in to CVS and
store them in there.
HTH,
Eric
Previous Topic:configuration error
Next Topic:Can't use the help
Current Time: Sat Aug 30 23:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.29069 seconds
