Home » Eclipse Projects » Eclipse Platform » What's the difference between "Run Configurations" and "Debug Configurations"?
What's the difference between "Run Configurations" and "Debug Configurations"? [message #336526] Fri, 19 June 2009 04:07 Go to next message
Configurations"? I mean, "Run Configurations" also supports debugger
settings, and I can choose to display an entry from debug configurations
under the "Run" faviourites menu and vice versa - so why are there two
separate sets of configurations?
Re: What's the difference between "Run Configurations" and "Debug Configurations" [message #336527 is a reply to message #336526] Fri, 19 June 2009 04:21 Go to previous messageGo to next message
They're not separate sets of configurations. The only difference is the
title and action of the button in the wizard.
> configurations under the "Run" faviourites menu and vice versa - so
> why are there two separate sets of configurations?
Re: What's the difference between "Run Configurations" and "Debug Configurations" [message #336541 is a reply to message #336527] Mon, 22 June 2009 02:38 Go to previous messageGo to next message
The Debug supports both run and debug mode and its up to the extensions
to make use of them. Most of them support both modes for their
configurations, but few like "Remote Java application" makes sense only
in the debug mode. Also depending on the mode, the configuration can
change some of their parameters (like classpath) - its left to the
configuration.
- Prakash
http://blog.eclipse-tips.com
Re: What's the difference between "Run Configurations" and "Debug Configurations" [message #336554 is a reply to message #336541] Mon, 22 June 2009 11:00 Go to previous message
> in the debug mode.
Of course.
The real question, though, is if there could be a common "Run and Debug
configurations..." menu entry - which would essentially display the same
as "Debug Configurations..." today. I mean, there is not exactly a lack of
items to display in the Run menu...
> configuration.
Hmmm... It's not entirely clear to me how a common dialog would impact
this...
- Toralf
> - Prakash
Previous Topic:UTF-8 Encoding
Next Topic:Full text searching
Current Time: Mon Jul 21 22:08:29 EDT 2025
Powered by FUDForum. Page generated in 0.05639 seconds
