Home » Archived » M2M (model-to-model transformation) » ATL and files
ATL and files [message #34168] Wed, 25 April 2007 12:06 Go to next message
Originally posted by: angelsaneg.yahoo.es
I would like to know if in atl is possible to work with files, to be able
to open, read and write in files from Atl.
thank you very much
greetings
Angel
Re: ATL and files [message #34341 is a reply to message #34168] Thu, 26 April 2007 04:07 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Angel,
What kind of files are you talking about ? What do you want to do ? This
would help replying more accurately.
Mikael
ANgel Sanchez wrote:
> Hello,
> able to open, read and write in files from Atl.
> thank you very much
> greetings
> Angel
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: ATL and files [message #34441 is a reply to message #34341] Thu, 26 April 2007 04:57 Go to previous messageGo to next message
hello again,
I was speaking about if text files could be treated in ATL . This files
would have some decisions of design to help to do the transformation from
an initial model to the target model. Due to this, I would like to know
if from atl, text files can be read, without they are including like
models of entrance(source models) in the atl transformation.
I hope that now you understand me.
greetings, Angel
Re: ATL and files [message #34475 is a reply to message #34441] Thu, 26 April 2007 05:07 Go to previous messageGo to next message
So the answer is no. But you can build an annotation model instead of
describing your design decisions in a raw text file. Annotation models
are weaving models. You can have a short description of annotation
models here: http://www.eclipse.org/gmt/amw/usecases/annotation/
You can also ask questions on the AMW newsgroup
(news://eclipse.modeling.gmt.amw) for more information about how to use
this annotation model in your transformation.
Mikael
Angel Sanchez wrote:
> hello again,
> from an initial model to the target model. Due to this, I would like to
> know if from atl, text files can be read, without they are including
> like models of entrance(source models) in the atl transformation.
> greetings, Angel
Re: [ATL] ATL and files [message #34776 is a reply to message #34475] Fri, 27 April 2007 11:27 Go to previous message
I would argue that the answer is actually yes. However, you need to
follow the model engineering principles. ATL is not a GPL (General
Purpose Language) like Java, but a model transformation DSL (Domain
Specific Language) like SQL for database queries.
Following the model engineering principles here means that you have to
consider your additional file as a model. The following Howto entry
gives more information on how to do this:
http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_use_ex tern_parameters_in_ATL_transformations.3F
This Howto entry uses an XML file to provide additional arguments to the
transformation. However, if you prefer a textual syntax, you may use TCS
instead:
http://wiki.eclipse.org/index.php/TCS
With TCS, you may even be able to use the very same format you were
already trying to use.
Finally, I must say that it is even better (because closest to the model
engineering principles) to define this additional model as a weaving
model, as Mikaël suggested. Furthermore, IIRC Mikaël has shown that it
is possible to use TCS to define such an annotation model that is also a
weaving model.
Frédéric Jouault
P.S.: Please, remember to prefix the subjects of your ATL-related posts
on this newsgroup with [ATL].
Mikaël Barbero wrote:
> Best regards,
> Mikael
>> hello again,
>> files would have some decisions of design to help to do the
>> transformation from an initial model to the target model. Due to
>> this, I would like to know if from atl, text files can be read,
>> without they are including like models of entrance(source models) in
>> greetings, Angel
Previous Topic:[ATL] need to do a calcul one Time
Next Topic:[ATL] how to delete an element used do block in matched rules
Current Time: Sun Aug 31 01:53:26 EDT 2025
Powered by FUDForum. Page generated in 0.03726 seconds
