Home » Eclipse Projects » Eclipse Platform » Can't find 64-bit build of Galileo RC4 for OS X
Can't find 64-bit build of Galileo RC4 for OS X [message #336477] Tue, 16 June 2009 10:14 Go to next message
I'm trying to run Galileo for OS X using Java 1.6. My understanding is
that this only works for 64-bit builds (because the 1.6 JVM is only built
for 64 bit). I downloaded the "Cocoa" version of Galileo RC4, but it
doesn't seem to be 64 bit, based on this:
mwallace-70004% file eclipse
eclipse: Mach-O universal binary with 2 architectures
eclipse (for architecture i386): Mach-O executable i386
eclipse (for architecture ppc): Mach-O executable ppc
When I try to run eclipse using 1.6, I get the following:
mwallace-70004% ./eclipse
_NSJVMLoadLibrary: NSAddLibrary failed for
/System/Library/Frameworks/JavaVM.framework/Versions/1.6/Lib raries/libjvm.dylib
JavaVM FATAL: Failed to load the jvm library.
Any help would be greatly appreciated.
Re: Can't find 64-bit build of Galileo RC4 for OS X [message #336478 is a reply to message #336477] Tue, 16 June 2009 10:19 Go to previous messageGo to next message
Not sure where you are looking but this page [1] explicitly shows the
64-bit version.
[1] http://download.eclipse.org/eclipse/downloads/drops/S-3.5RC4 -200906051444/index.php
Tom
> built for 64 bit). I downloaded the "Cocoa" version of Galileo RC4, but
> it doesn't seem to be 64 bit, based on this:
> mwallace-70004% ./eclipse _NSJVMLoadLibrary: NSAddLibrary failed for
Re: Can't find 64-bit build of Galileo RC4 for OS X [message #336479 is a reply to message #336478] Tue, 16 June 2009 14:35 Go to previous message
The packages that you find here [1] are only built for 32-bit cocoa, not
for 64 bit.
To get the 64bit cocoa build, you need the "Eclipse Classic" -> Other
downloads, which is the link that Tom gave.
Starting from that base Eclipse, you can install other things you may
want by doing Help -> Install New Software... and work with the Galileo
repository.
[1] http://www.eclipse.org/downloads/?tab=developer
-Andrew
Tom Schindl wrote:
> 64-bit version.
> Tom
Previous Topic:Use activities to hide objectContribution from popup menus
Next Topic:Forms and Dialogs
Current Time: Sun Aug 31 04:51:57 EDT 2025
Powered by FUDForum. Page generated in 0.03089 seconds
