Home » Eclipse Projects » Sirius » Label alignment 'center' not working for svg workspace image style
Label alignment 'center' not working for svg workspace image style [message #1816850] Fri, 08 November 2019 05:44 Go to next message
I have some node mappings that use a workspace image style, pointing to svg graphics. I have set the label alignment to center, but the labels are aligned on the left when elements are created. Any ideas?
Re: Label alignment 'center' not working for svg workspace image style [message #1816932 is a reply to message #1816850] Tue, 12 November 2019 05:55 Go to previous message
Hi Felix,
In org.eclipse.sirius.diagram.ui.internal.edit.parts.WorkspaceImageEditPart.refreshVisuals() it seems that the label alignment update is correctly called.
Do you have a simple reproduction case (a simple VSM on Ecore for example) ?
Previous Topic:Getting the source and target for displayed edges
Next Topic:Get selected item value in capella diagram
Current Time: Mon Jul 14 12:50:26 EDT 2025
Powered by FUDForum. Page generated in 0.03307 seconds
