Home » Eclipse Projects » Eclipse Platform » Documentation for variables in Plug-In extension editor
Documentation for variables in Plug-In extension editor [message #336410] Wed, 10 June 2009 07:27 Go to next message
Hello.
When I look at
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/guide/tools/editors/manifest_editor/extension s.htm
in the documentation, then there are variables used like %perspective.name (a reference to a
resource) and $nl$ in the Plug-in extension editor.
Is that somewhere documented?
Is it also somehow possible to reference a "public static final String" field of a class as id?
Cause I sometimes also have to use those id's in my code, and it is quite unhandy if I have to
change an id. Then I have to search my code and change all occurrences manually.
Kai
Re: Documentation for variables in Plug-In extension editor [message #336416 is a reply to message #336410] Wed, 10 June 2009 11:42 Go to previous messageGo to next message
Kai Schlamp wrote:
> Hello.
> When I look at
> %perspective.name (a reference to a resource) and $nl$ in the Plug-in
> extension editor.
> String" field of a class as id? Cause I sometimes also have to use
> those id's in my code, and it is quite unhandy if I have to change an
If you define the attribute type to be 'java' then the Rename
refactoring updates the plugin.xml for you when you rename a class.
Dani
> Kai
Re: Documentation for variables in Plug-In extension editor [message #336418 is a reply to message #336416] Wed, 10 June 2009 12:45 Go to previous messageGo to next message
Yes, I know. But how about for example the id for a command.
I often programmatically execute commands with the help of the IHandlerService. A id of the handler
must be specified then. The id that was used in the declarative extensions.
When I now change the id in the declarative extension, then I also have to change the id in the
source code.
Re: Documentation for variables in Plug-In extension editor [message #336426 is a reply to message #336418] Thu, 11 June 2009 01:57 Go to previous messageGo to next message
> IHandlerService. A id of the handler must be specified then. The id
> have to change the id in the source code.
There's no support except to simply use text search & replace.
Dani
Re: Documentation for variables in Plug-In extension editor [message #336437 is a reply to message #336410] Thu, 11 June 2009 12:11 Go to previous message
Kai Schlamp wrote:
> Hello.
> When I look at
> extension editor.
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/product_def_nl.htm
http://www.eclipse.org/articles/Article-Internationalization /how2I18n.html
Previous Topic:WizardResourceImportPage.createDestinationGroup is final?
Next Topic:Schedule UIJob in Activator.start()
Current Time: Sat Nov 08 06:35:11 EST 2025
Powered by FUDForum. Page generated in 0.03597 seconds
