Home » Eclipse Projects » Eclipse Platform » default encoding
default encoding [message #336402] Wed, 10 June 2009 04:14 Go to next message
I'm using Galileo RC3.
I want the default workspace encoding to be UTF-8. At the moment, each time
I create a new workspace I have to set the encoding to UTF-8 (I sometimes
forget and get punished). Any way of doing this?
Zohar.
Re: default encoding [message #336412 is a reply to message #336402] Wed, 10 June 2009 08:11 Go to previous messageGo to next message
zohar wrote:
> Hello,
> time I create a new workspace I have to set the encoding to UTF-8 (I
> sometimes forget and get punished). Any way of doing this?
If you have your projects in a repository then the best way is to set
the encoding on the project and hence share it.
To make sure you don't forget to the workspace setting you could use a
start script that sets the file.encoding property.
Dani
> Zohar.
Re: default encoding [message #336430 is a reply to message #336412] Thu, 11 June 2009 06:45 Go to previous messageGo to next message
1. how do I save this setting for the project?
2. are there any command line args I can use to do that?
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:h0o7u8$es6$1@build.eclipse.org...
> zohar wrote:
>> Hello,
> If you have your projects in a repository then the best way is to set the
> Dani
>> Thanks,
>> Zohar.
Re: default encoding [message #336433 is a reply to message #336430] Thu, 11 June 2009 08:05 Go to previous message
If your project is shared with a team provider (e.g. CVS) then you will
see a change after setting the project encoding. Simply commit that change.
-vmargs -Dfile.encoding=UTF-8
Dani
>> zohar wrote:
>>> Hello,
>>> each time I create a new workspace I have to set the encoding to
>>> UTF-8 (I sometimes forget and get punished). Any way of doing this?
>> a start script that sets the file.encoding property.
>> Dani
>>> Thanks,
>>> Zohar.
Previous Topic:[Update Site] metadata
Next Topic:WizardResourceImportPage.createDestinationGroup is final?
Current Time: Fri Nov 21 19:48:46 EST 2025
Powered by FUDForum. Page generated in 0.03604 seconds
