Home » Eclipse Projects » Eclipse Platform » WizardResourceImportPage.createDestinationGroup is final?
WizardResourceImportPage.createDestinationGroup is final? [message #336396] Wed, 10 June 2009 03:54 Go to next message
I was trying to reuse parts of the WizardResourceImportPage in one of my
wizards, and I wanted to modify the part containing the destination
widgets, but I couldn't do that as this method was declared final in the
class.
Is there a reason why this particular method is final, while
createSourceGroup and createOptionsGroup are not.
Thanks in advance,
Mamado
Re: WizardResourceImportPage.createDestinationGroup is final? [message #336406 is a reply to message #336396] Wed, 10 June 2009 05:21 Go to previous messageGo to next message
Not sure of why its been final, ideally it shouldn't be. You can
still override the createControl() and customize your UI.
- Prakash
http://blog.eclipse-tips.com
Re: WizardResourceImportPage.createDestinationGroup is final? [message #336408 is a reply to message #336406] Wed, 10 June 2009 05:54 Go to previous messageGo to next message
Thanks a lot Prakash,
I understand this, but I wanted to avoid duplicating code as much as I
can, but I will have to do this at the end I guess.
Is there a way to modify this, shall I open a bug on the platform?
Best Regards,
Mamado.
> - Prakash
Re: WizardResourceImportPage.createDestinationGroup is final? [message #336425 is a reply to message #336408] Thu, 11 June 2009 01:34 Go to previous messageGo to next message
Yes. That would be the right way to go
- Prakash
Re: WizardResourceImportPage.createDestinationGroup is final? [message #336434 is a reply to message #336425] Thu, 11 June 2009 10:03 Go to previous message
Done, https://bugs.eclipse.org/bugs/show_bug.cgi?id=279902
Previous Topic:default encoding
Next Topic:Documentation for variables in Plug-In extension editor
Current Time: Sat Jul 26 23:08:15 EDT 2025
Powered by FUDForum. Page generated in 0.28458 seconds
