Where is the documentation [message #34142] |
Tue, 16 May 2006 14:32  |
Originally posted by: solomono.yahoo.com
I have loaded the EMFT projects into my workspaces and can see that they
are available as plugins. However I do not find the documentation in
Eclipse help.
Do I have to build the projects from SVN.
Also initially it appears the parser generator used for OCL was antlr
why was this changed
Solomon
Re: Where is the documentation [message #34210 is a reply to message #34176] |
Tue, 16 May 2006 17:22  |
Hi, Solomon,
You should see the documentation for the EMFT projects in the on-line help
if you installed the *.doc features. Look for the "EMFT OCL Programmer's
Guide", "EMFT Validation Programmer's Guide", etc. topics in the help
browser.
If you installed the SDK zips, then you should have the *.doc features
because the *.sdk features include the *.doc. Otherwise, if you are
installing using Update Manager, then you may need to explicitly select
them if you do not select the *.sdk features.
HTH,
Christian
Solomon Obi wrote:
> Solomon Obi wrote:
>> Hi
>> Eclipse help.
>> Thanks
>> Solomon
> I apologise I asked the latter questions previously
> Solomon
Re: Where is the documentation [message #577669 is a reply to message #34142] |
Tue, 16 May 2006 14:37  |
Solomon Obi wrote:
> Hi
> Eclipse help.
> Thanks
> Solomon
Solomon
Re: Where is the documentation [message #577704 is a reply to message #34176] |
Hi, Solomon,
browser.
HTH,
Christian
Solomon Obi wrote:
> Solomon Obi wrote:
>> Hi
>> Eclipse help.
>> Thanks
>> Solomon
> Solomon
FUDForum. Page generated in 0.02825 seconds
