Home » Eclipse Projects » Eclipse Platform » How to tailor the Conext menu of text editor?
How to tailor the Conext menu of text editor? [message #336275] Thu, 04 June 2009 16:26 Go to next message
Dear All,
To explain the question, I have a screen shot at
http://www.frankdu.com/tmp/embed_editor.png.
In the context menu of the xml editor, I don't want the following items:
Run As
Debug As
Profile As
Team
Compare With
Replace With
How could we remove the unwanted ones, or customize it?
Thank you so much! Have a good one day!
Best Regards,
Frank Du
http://www.frankdu.com/weblog
Re: How to tailor the Conext menu of text editor? [message #336298 is a reply to message #336275] Fri, 05 June 2009 10:44 Go to previous messageGo to next message
Frank Du wrote:
> Dear All,
> Run As
> Debug As
> Profile As
> Team
> Compare With
> Replace With
Those are the ones contributed via editor input. You can remove them by
overriding
org.eclipse.ui.texteditor.AbstractTextEditor.isEditorInputIn cludedInContextMenu()
in your editor.
Dani
> Best Regards,
> Frank Du
Re: How to tailor the Conext menu of text editor? [message #336310 is a reply to message #336298] Fri, 05 June 2009 13:47 Go to previous messageGo to next message
Hi Daniel,
Thank you so much for the answer. I am curious about a question: is there
a way to easily list contribution plug-ins that provide context menu
actions?
Thank you so much! Have a nice weekend!
Best Regards,
Frank Du
> overriding
> in your editor.
> Dani
Re: How to tailor the Conext menu of text editor? [message #336314 is a reply to message #336310] Sun, 07 June 2009 11:52 Go to previous message
Frank Du wrote:
> Hi Daniel,
> there a way to easily list contribution plug-ins that provide context
> menu actions?
You have to parse the extension in your plugin.xml files.
Dani
> Best Regards,
> Frank Du
>> by overriding
>> in your editor.
>> Dani
Previous Topic:How to make an editor readonly
Next Topic:Over riding copy paste
Current Time: Sat Nov 08 17:24:45 EST 2025
Powered by FUDForum. Page generated in 0.24763 seconds
