Home » Eclipse Projects » Eclipse Platform » Starting help system webapp
Starting help system webapp [message #336246] Wed, 03 June 2009 06:26 Go to next message
I'm trying to integrate documentation into a headless server application
running on the Eclipse platform so that the help pages can be consulted
with a browser.
As far as I understand the system, one way to start the 'help' webapp is
to use the org.eclipse.help.standalone.Help or
org.eclipse.help.standalone.InfoCenter classes. However, these start a new
instance of Eclipse, which is silly because I already have one running.
At the moment I'm calling
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning() and
ignoring the warnings about discouraged access. The problem with this
approach is that I can't seem to configure the webapp's port (unless I
pass the -Dserver_port VM argument, which is not an option as we have a
centralized configuration file which should contain this kind of setting).
Is there an API (that allows specifying critical parameters such as
listening port) to get the help webapp started from an Eclipse-based
application?
Bert Vingerhoets
Re: Starting help system webapp [message #336249 is a reply to message #336246] Wed, 03 June 2009 11:13 Go to previous message
Originally posted by: nospam_kowalskilee.gmail.com
Hi Bert,
Is your question more like how to get the help webapp started from an
Eclipse-based application without starting a new instance of Eclipse?
I recommend that you re-post your question to the eclipse.platform.ua
newsgroup. The Eclipse UA committers monitor that group and will more
likely see a posting there.
Hope this helps,
Lee Anne
Bert Vingerhoets wrote:
> with a browser.
> new instance of Eclipse, which is silly because I already have one running.
> application?
> Bert Vingerhoets
Previous Topic:Add New Wizards to the File>New shortcut
Next Topic:alt-tab icon
Current Time: Thu Jul 17 17:11:49 EDT 2025
Powered by FUDForum. Page generated in 0.27150 seconds
