Home » Eclipse Projects » Eclipse Platform » Cannot set Key Binding for Compare with -> Local History
Cannot set Key Binding for Compare with -> Local History [message #336223] Mon, 01 June 2009 00:38 Go to next message
Hi All,
I like the Eclipse feature Compare with -> Local History, but is there a
way to set a key binding for it? Under "Window > Preferences General >
Keys" I cannot see that action at all.
Thanks for any advice!
Rob
Re: Cannot set Key Binding for Compare with -> Local History [message #336226 is a reply to message #336223] Mon, 01 June 2009 09:32 Go to previous messageGo to next message
Remove the filter... so you can see uncategorized commands, and then
search for "Local History"
You'll have to look at the description of each one, to see which is the
correct one.
PW
Paul Webster
Re: Cannot set Key Binding for Compare with -> Local History [message #336229 is a reply to message #336226] Tue, 02 June 2009 01:36 Go to previous message
> commands, and then search for "Local History"
> to see which is the correct one.
Thanks Paul - that worked nicely.
The short-cut didn't work.. until I realised I cannot activate it from the
Editor: I can only activate it from an explorer view like Navigator. Also,
there are two views that compare with local history, one that displays
results in the History view, another that displays results in a pop-up. In
the Preferences > General > Keys view, there is nothing to separate them.
Oh well, I don't mind - I set a keyboard command for each one. :)
Rob
Previous Topic:Common Navigator Framework and drag out to Windows
Next Topic:Error message: "Exception occurred creating launch configuration tabs"
Current Time: Mon Nov 03 03:42:23 EST 2025
Powered by FUDForum. Page generated in 0.68632 seconds
