Home » Eclipse Projects » Eclipse Platform » command line and UI in same application
command line and UI in same application [message #336193] Thu, 28 May 2009 11:05 Go to next message
We have an application that can be run in a command line or GUI mode,
depending on the parameters passed in at startup.
The command line processing is done before creating the display and the
workbench.
However, when running in command line mode, the application still tries to
connect to the display.
Any idea what could be causing this and if there is any options turn that
off?
PS: I found a similar post
( http://dev.eclipse.org/newslists/news.eclipse.platform/msg79 942.html) but
unfortunately without any answers...
command line and UI in same application - RESOLVED [message #336194 is a reply to message #336193] Thu, 28 May 2009 11:45 Go to previous message
issue solved by adding a -noSpash in the .ini file ...
Previous Topic:linked resources and CVS
Next Topic:[problemsView]why not to try to adapt EditorInput in ITaskListResourceAdapter
Current Time: Sat Nov 08 17:24:30 EST 2025
Powered by FUDForum. Page generated in 0.03128 seconds
