Home » Eclipse Projects » Eclipse Platform » [CommonNavigator] showing wizards
[CommonNavigator] showing wizards [message #336122] Fri, 22 May 2009 15:22 Go to next message
Originally posted by: aczerwonka.3esi.com
Can anyone point me to a solution that would solve the two use cases
depicted in the attached example.png?
-andy
  • Attachment: example.png
    (Size: 70.93KB, Downloaded 139 times)
Re: [CommonNavigator] showing wizards [message #336123 is a reply to message #336122] Fri, 22 May 2009 15:28 Go to previous message
Oops.. the original diagram showed the Open and Delete menus showing up in
Use Case #2. That was incorrect and has been fixed.
Note that I do have the Open and Delete working just fine via actionProvider
extensions. It's the New menu that I'm really trying to add.
"Andy Czerwonka" <aczerwonka@3esi.com> wrote in message
news:gv6u1e$8pq$1@build.eclipse.org...
> -andy
    (Size: 70.50KB, Downloaded 139 times)
Previous Topic:PluginModelManager.initializeTable() problem in self-hosted application
Next Topic:[Databinding] db-related objects lifecycle and (listeners) management
Current Time: Mon Sep 08 01:56:48 EDT 2025
Powered by FUDForum. Page generated in 0.06638 seconds
