Home » Eclipse Projects » Eclipse Platform » specifying location of a new group to be added the file menu
specifying location of a new group to be added the file menu [message #336093] Wed, 20 May 2009 20:43 Go to next message
I have been trying to add a new menu item under the file menu which will
also be its own group, that is, it will be surrounded by separators. I
would like to put this new group after the fileStart group (that is, after
the separator following the "New" and "Open File.."). I have successfully
created the new menu item with the seperators but by default this new item
is placed between the "Export.." and "Properties" menu items. I have been
reading the help file but have not yet found a way to place it where I
want it to go. Has anyone tried to do this before? If so, will you please
give me some advice?
Re: specifying location of a new group to be added the file menu [message #336102 is a reply to message #336093] Thu, 21 May 2009 09:22 Go to previous message
Check out
org.eclipse.ui.internal.ide.WorkbenchActionBuilder.createFil eMenu() to
see the structure that is created for the File menu. What are you doing
to add these? In org.eclipse.ui.menus, the locationURI would be
something like menu:file?after=<id> where <id> is the ID of something
(like a group marker or separator) to begin inserting after.
PW
Paul Webster
Previous Topic:[CommonNavigator] How to use wizards?
Next Topic:Locate Eclipse executable at runtime?
Current Time: Wed Nov 19 23:31:21 EST 2025
Powered by FUDForum. Page generated in 0.24752 seconds
