Home » Eclipse Projects » Eclipse Platform » [CommonNavigator] Adding the New Menu
[CommonNavigator] Adding the New Menu [message #336090] Wed, 20 May 2009 16:47 Go to next message
I'm trying to add the New Wizard Menu to the Common Navigator. I have
the following in my plugin.xml:
<navigatorContent
activeByDefault="true"
contentProvider="com.ap.projectsets.navigator.ProjectSetsContentProvider "
icon="icons/folder_gear.png"
id="com.ap.projectsets.projectSetsContent"
labelProvider="com.ap.projectsets.navigator.ProjectSetsLabelProvider "
name="Project Sets"
priority="higher"
providesSaveables="false">
<triggerPoints>
<or>
<instanceof value="com.ap.navigator.ManageNavigator$Root" />
<instanceof
value="com.ap.projectsets.ProjectsSetsModel$Root" />
</or>
</triggerPoints>
<possibleChildren>
<or>
<instanceof
<instanceof value="com.ap.projectsets.ProjectSet" />
</or>
</possibleChildren>
<actionProvider
class="com.ap.projectsets.navigator.ProjectSetsActionProvider "
id="com.ap.projectsets.navigator.ProjectSetsActionProvider" >
</actionProvider>
<commonWizard
type="new"
wizardId="com.ap.projectsets.wizards.NewProjectSetWizard">
<enablement>
<or>
<instanceof
value="com.ap.projectsets.ProjectSet">
</instanceof>
<instanceof
value="com.ap.projectsets.ProjectsSetsModel$Root">
</instanceof>
<instanceof
value="com.ap.navigator.ManageNavigator$Root">
</instanceof>
</or>
</enablement>
</commonWizard>
</navigatorContent>
The NewProjectSetWizard is configured and working in the main toolbar,
but I can't get it to show up in the Common Navigator. Do I have to
somehow add the menu first before the wizard can attach?
Re: [CommonNavigator] Adding the New Menu [message #336127 is a reply to message #336090] Mon, 25 May 2009 04:02 Go to previous message
Did you bind your navigatorContent with specific instance of
CommonNavigator through ViewerContentBinding extension point?
CommonNavigator is not static single navigator. you needs to define an
instanceof CommonNavigator or use one already defined.
then
you need to bind your content with an instance of CommonNavigator
through ViewerContentBinding Extension.
> <navigatorContent
> name="Project Sets"
> priority="higher"
> <triggerPoints>
> <or>
> <instanceof
> <instanceof
> </or>
> </triggerPoints>
> <possibleChildren>
> <or>
> <instanceof
> </or>
> </possibleChildren>
> <actionProvider
> </actionProvider>
> <commonWizard
> type="new"
> <enablement>
> <or>
> <instanceof
> </instanceof>
> <instanceof
> </instanceof>
> <instanceof
> </instanceof>
> </or>
> </enablement>
> </commonWizard>
> </navigatorContent>
Previous Topic:Problems generating a headless build application
Next Topic:Why the problemd view don't use the AdapterManager
Current Time: Fri Nov 21 00:28:06 EST 2025
Powered by FUDForum. Page generated in 0.03970 seconds
