Home » Eclipse Projects » Eclipse Platform » Why the problemd view don't use the AdapterManager
Why the problemd view don't use the AdapterManager [message #336080] Wed, 20 May 2009 11:15 Go to next message
The problems views test if the selection is an IAdaptable and try to
adapt this one in different classes able to give the resource associated
to the selection.
But why not use the AdapterManager (Platform.getAdapterManager)?
@see in org.eclipse.ui.internal.views.markers.ExtendedMarkersView, line
989 :
if (selection instanceof IStructuredSelection) {
for (Iterator iterator = ((IStructuredSelection) selection)
.iterator(); iterator.hasNext();) {
Object object = iterator.next();
if (object instanceof IAdaptable) {
Re: Why the problemd view don't use the AdapterManager [message #336082 is a reply to message #336080] Wed, 20 May 2009 13:05 Go to previous messageGo to next message
> to the selection.
Interesting! I guess its worth to file a bug.
- Prakash
http://blog.eclipse-tips.com
Re: Why the problemd view don't use the AdapterManager [message #336089 is a reply to message #336080] Wed, 20 May 2009 13:56 Go to previous messageGo to next message
As Prakash mentioned, please file a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
In the workbench, we should try and use
org.eclipse.ui.internal.util.Util.getAdapter(Object, Class) to adapt
objects.
PW
Paul Webster
Re: Why the problemd view don't use the AdapterManager [message #336131 is a reply to message #336089] Mon, 25 May 2009 06:18 Go to previous message
it's done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=277646
> objects.
> PW
Previous Topic:[CommonNavigator] Adding the New Menu
Next Topic:Strange behaviour of an open shell (needs a mouse click twice before noticing any event on the shell
Current Time: Sat Aug 30 08:13:09 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
