Home » Eclipse Projects » Eclipse Platform » path in editor menus
path in editor menus [message #336078] Tue, 19 May 2009 21:24 Go to next message
In Extension Points Reference Menus for Editor Munus, Toolbars and
Actions, I find the following description for munu:
<!ELEMENT menu (separator* , groupMarker*)>
<!ATTLIST menu
id CDATA #REQUIRED
label CDATA #REQUIRED
path CDATA #IMPLIED>
This element is used to defined a new menu.
id - a unique identifier that can be used to reference this menu.
label - a translatable name used by the Workbench for this new menu. The
name should include mnemonic information.
path - the location of the new menu starting from the root of the menu.
Each token in the path must refer to an existing menu, except the last
token which should represent a named group in the last menu in the path.
If omitted, the new menu will be added to the additions named group of the
menu.
Can some explain path in details based on the following example:
<menu
label="%_UI_ValidationMenu_label"
path="org.eclipse.example.loyaltyMenuID/additions"
id="org.eclipse.emf.validationMenuID">
<separator name="additions"/>
</menu>
So org.eclipse.example.loyaltyMenuId is an existing menu, where can I find
it? Thanks.
Will
Re: path in editor menus [message #336088 is a reply to message #336078] Wed, 20 May 2009 13:53 Go to previous messageGo to next message
> <menu
> </menu>
> find it? Thanks.
That is defined somewhere else, in actionSets in the same contribution,
in popupMenus/objectContributions simply in another contribution.
ex:
<menu id="top" label="Top Menu" path="additions">
</menu>
<menu id="sub" label="Sub Menu" path="top/additions">
</menu>
<menu id="subsub" label="Sub Sub Menu" path="top/sub/additions">
</menu>
This creates the cascading menu: Top Menu>Sub Menu>Sub Sub Menu
PW
Paul Webster
Re: path in editor menus [message #336092 is a reply to message #336088] Wed, 20 May 2009 19:06 Go to previous messageGo to next message
Paul Webster wrote:
>> <menu
>> </menu>
>> find it? Thanks.
I still get the confused about what you said here. In the description,
it says "path - the location of the new menu starting from the root of the
menu. Each token in the path must refer to an existing menu". I find
org.eclipse.example.loyaltyMenuId is shown in the menupath under action
element as follows:
<action
menubarPath=" org.eclipse.example.loyaltyMenuId/org.eclipse.emf.validation MunuID/additions "
</action>
So you mean org.eclipse.example.loyaltyMenuId is defined in the
menubarPath?
> ex:
> </menu>
Here top in the path refers to the id's value give in the first menu?
Or sth else? Thanks.
Will
> </menu>
> </menu>
> PW
Re: path in editor menus [message #336101 is a reply to message #336088] Thu, 21 May 2009 09:17 Go to previous messageGo to next message
> </menu>
> </menu>
> </menu>
First it defines "Top Menu" with an id of "top". Then it defines a "Sub
Menu" in the "top" menu with an id of "sub". Then it defines a "Sub Sub
Menu" in the "sub" menu with an id of "subsub".
Just like a directory structure, you have to define a path of IDs
terminating with a group/separator name. i.e. if I wanted to add an
action to the Sub Sub Menu, my menubarPath would be
"top/sub/subsub/additions"
PW
Paul Webster
Re: path in editor menus [message #336109 is a reply to message #336101] Thu, 21 May 2009 10:55 Go to previous messageGo to next message
Paul,
Thanks for the reply. I still want to make sure that I get the idea.
>> </menu>
What happen if path="A.B.C/additions"? in the above top menu. Is A.B.C
a menu id, right? Where can I find it? Or A.B.C is the directory where you
can find menu whose id is top?
>> </menu>
Is top a menu id or the path where you find the menu whose id is top?
Thanks.
Will
>> </menu>
> PW
Re: path in editor menus [message #336111 is a reply to message #336109] Thu, 21 May 2009 13:59 Go to previous messageGo to next message
Williams wrote:
> Paul,
>>> </menu>
This only works if you've already defined a <menu/> whose id="A.B.C".
path="additions" is the GroupMarker in the main menu bar, between the
Project and Window menus.
>>> </menu>
> Thanks.
top is the id of the menu I created in my first menu element.
Later,
PW
Paul Webster
Re: path in editor menus [message #336112 is a reply to message #336111] Thu, 21 May 2009 15:38 Go to previous messageGo to next message
Paul Webster wrote:
> Williams wrote:
>> Paul,
>>>> </menu>
I came to this question from the EMF General Validation Example.
After I search org.eclipse.emf.examples.extlibraryMenuID based on the
following declaration in the plugin.xml file:
path="org.eclipse.emf.examples.extlibraryMenuID/additions"
I cannot find another place to define a menu whose id is
"org.eclipse.emf.examples.extlibraryMenuID". However, I find the following
statement:
208: IMenuManager submenuManager = new
MenuManager(EXTLibraryEditorPlugin.INSTANCE.getString("_UI_EXTLibraryEditor_menu "),
"org.eclipse.emf.examples.extlibraryMenuID"); //$NON-NLS-1$ //$NON-NLS-2$
in one of the java files. Does the above statement define that menu id? To
verify this, I only replace org.eclipse.emf.examples.extlibraryMenuID with
A in the plugin.xml file. The EMF Validation Example still works without
changing the above Java Statement? I get confused here...
>>>> </menu>
>> Thanks.
I fully understand this now.
will
Re: path in editor menus [message #336118 is a reply to message #336112] Fri, 22 May 2009 08:21 Go to previous message
> following statement:
> To verify this, I only replace org.eclipse.emf.examples.extlibraryMenuID
> with A in the plugin.xml file. The EMF Validation Example still works
> without changing the above Java Statement? I get confused here...
I don't know why it still works. But yes, this is programmatically
defining a menu with an ID of org.eclipse.emf.examples.extlibraryMenuID.
Check out
org.eclipse.ui.internal.ide.WorkbenchActionBuilder.createFil eMenu() It
creates a MenuManager with id=file.
This can then be used as menubarPath="file/additions" in plugin.xml
PW
Paul Webster
Previous Topic:Re: Making View Visible After Mouse Click
Next Topic:Moving resources between projects
Current Time: Tue Oct 14 21:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.05023 seconds
