Home » Eclipse Projects » Eclipse Platform » Access handler reference
Access handler reference [message #336063] Mon, 18 May 2009 05:18 Go to next message
Would anyone know how to access the instance of a handler, given the
command ID? I know the handler is instantiated by the workbench, and I
need call a method on it - i'd rather not instantiate it again.
Cheers!
Re: Access handler reference [message #336086 is a reply to message #336063] Wed, 20 May 2009 13:41 Go to previous message
You can't get to a handler, at least not from the framework.
You could have your handler post itself to your plugin Activator, so you
can retrieve it from there once it is created.
ex: class MyHandler {....
public MyHandler() {
Activator.getDefault().setHandler(this);
Then you can use it Activator.getDefault().getHandler()!=null etc
PW
Paul Webster
Previous Topic:Auto close of editor area when last editor closed
Next Topic:Menu bar not checking handler enablement
Current Time: Thu Jul 17 23:58:45 EDT 2025
Powered by FUDForum. Page generated in 0.03146 seconds
