Home » Newcomers » Newcomers » Blank buttons
Blank buttons [message #34102] Mon, 14 March 2005 15:58 Go to next message
Originally posted by: faith.zack.plantronics.com
I just installed a new laptop and am having trouble with the display. I'm
getting blank or black buttons. I am using the vm from the Sun J2EE 1.4
SDK:
C:\Program Files\eclipse\eclipse.exe -vm C:\Sun\AppServer\jdk\bin\java.exe
Re: Blank buttons [message #34276 is a reply to message #34102] Mon, 14 March 2005 17:07 Go to previous messageGo to next message
Originally posted by: muhammad.dwyer.gmail.com
Try turning your video hardware acceleration down a few notches (at least
in you're running on Windows): Right click on desktop and choose properties:
Display Properties / Settings tab / Advanced button / Troubleshoot tab -
seriously decrease hardware acceleration.
Alternatively, upgrade to J2SDK 1.4_04 or JDK 1.5 (a.k.a. Java 5 or 'Tiger')
Note: the J2SE SDK you use should have no influence on which J2EE SDK you
can use (correct me if I'm wrong)
Best of luck!
Re: Blank buttons [message #34412 is a reply to message #34276] Mon, 14 March 2005 22:18 Go to previous messageGo to next message
Changing the video hardware acceleration had no effect. But I tried
adjusting the compatibility properties in the shortcut, and I found that
checking "Disable visual themes" resolved the problem fairly well for now
(the icons aren't as detailed, but still usable). I'll investigate
upgrading my SDK.
Thanks for the quick response,
Faith
> Best of luck!
Re: Blank buttons [message #34514 is a reply to message #34412] Tue, 15 March 2005 01:37 Go to previous message
Glad to see your up and running. I had an identical problem and solved it
by adjusting the hardware acceleration. This is a pain when playing a DVD
video or some games, coz then you have to readjust it to watch the movie
or play the game.
I noticed the problem seemed to resolve itself when I upgraded from J2SE
SDK 1.4_02 to 1.4_04.
Best of luck anyhow
> that checking "Disable visual themes" resolved the problem fairly well
> for now (the icons aren't as detailed, but still usable). I'll
> investigate upgrading my SDK.
> Faith
>> least in you're running on Windows): Right click on desktop and
>> choose properties: Display Properties / Settings tab / Advanced
>> button / Troubleshoot tab - seriously decrease hardware acceleration.
>> 'Tiger')
>> you can use (correct me if I'm wrong)
>> Best of luck!
Previous Topic:3.1M5a and WebDAV issue?
Next Topic:Filtering import help
Current Time: Thu Jul 31 12:53:45 EDT 2025
Powered by FUDForum. Page generated in 0.48881 seconds
