Re: What is the difference between the eclipse packages and the SDK? [message #336001 is a reply to message #335998] |
Wed, 13 May 2009 06:03   |
Originally posted by: TheRealHawk.Freenet.de
"Walter Harley" <eclipse@cafewalter.com> schrieb im Newsbeitrag
news:gudlmd$11k$1@build.eclipse.org...
> "Markus Koch" <TheRealHawk@Freenet.de> wrote in message
> news:gucnvc$g1b$1@build.eclipse.org...
>> Ok, I found out, that the SDK is "only" the classic-package.
>> But what other packages do I need for a nearly complete eclipse (rcp,
>> jee, ... + sources)?
> There is no such thing as a "nearly complete eclipse" - there are
> thousands of third-party plugins available. The whole point of Eclipse is
> that it is modular and ever-changing.
> Even within the small subset of Eclipse that is available on eclipse.org,
> it covers many different styles and needs.
> So you'll need to be a bit more specific about your "..."! But you can
> start with any of the packages and then add more features as you want with
> the update manager.
> From the buzzwords you do mention, it sounds like you want to start with
> the "Eclipse IDE for Java EE Developers" package, and then you'll probably
> need to add some RCP components.
That's right - primarily I want to develop RCP-applications but also want
the WTP-plugins (e.g. for html-, xml-editing).
Do you know what are the differences between RCP SDK and Platform SDK?
--> For RCP-development I need some eclipse-sources (e.g. jface, swt, ...)
Does the Platform-SDK contain the RCP-SDK or do I need both?
Markus
Re: What is the difference between the eclipse packages and the SDK? [message #336007 is a reply to message #336001] |
Wed, 13 May 2009 11:25   |
If I know I'm going to do any kind of plug-in or RCP development, I
always grab the package for Plug-in/RCP developers, then add whatever
else I need. In past versions, it was difficult to find and install the
various source plug-ins that are essential for plug-in development, so
that is why I start with that package. I think now it is easier to get
them post-installation, but that is my habit ;-)
So I'd get the Plug-in/RCP package and then install the web tools
(including JEE) features that you need.
Hope this helps,
Eric
Re: What is the difference between the eclipse packages and the SDK? [message #336015 is a reply to message #336007] |
Wed, 13 May 2009 12:21  |
"Eric Rizzo" <eclipse-news@rizzoweb.com> schrieb im Newsbeitrag
news:gueook$gs7$2@build.eclipse.org...
> If I know I'm going to do any kind of plug-in or RCP development, I always
> grab the package for Plug-in/RCP developers, then add whatever else I
> need. In past versions, it was difficult to find and install the various
> source plug-ins that are essential for plug-in development, so that is why
> I start with that package. I think now it is easier to get them
> Hope this helps,
> Eric
I'll try it.
Markus
FUDForum. Page generated in 0.03439 seconds
