Home » Eclipse Projects » Eclipse Platform » How do I manually drop plugins into an eclipse install in 3.5M7?
How do I manually drop plugins into an eclipse install in 3.5M7? [message #335963] Mon, 11 May 2009 14:21 Go to next message
I first tried dropping the plugin jar into the plugins directory. That
didn't work. Then I tried dropping it into the dropins directory in all
three supposedly supported formats (1 - directly under dropins; 2 - under
dropins/eclipse/plugins, 3 - under
dropins/<nameOfMyChoice>/eclipse/plugins). Nothing worked.
I guess using the Equinox p2 UI would solve my problem. But from the
documentation, it sounds like this is an entirely separate application that
I'd have to install. That's a lot of overhead to drop a single plugin into
my environment.
Matt
Re: How do I manually drop plugins into an eclipse install in 3.5M7? [message #335965 is a reply to message #335963] Mon, 11 May 2009 19:29 Go to previous messageGo to next message
> under dropins/eclipse/plugins, 3 - under
> that I'd have to install. That's a lot of overhead to drop a single
> plugin into my environment.
> Matt
Putting the plugin in the dropins folder should work. Have you
restarted your Eclipse install after dropping the plugin into the
dropins folder?
Have you checked to log file to see if there is a problem resolving the
plugins you are trying to dropin.
Re: How do I manually drop plugins into an eclipse install in 3.5M7? [message #335979 is a reply to message #335965] Tue, 12 May 2009 11:21 Go to previous messageGo to next message
"David Wegener" <dpwegener@gmail.com> wrote in message
news:guacde$kal$1@build.eclipse.org...
>> Thanks,
>> Matt
> Putting the plugin in the dropins folder should work. Have you restarted
> your Eclipse install after dropping the plugin into the dropins folder?
Yes.
There was no mention of the problem in the log.
Re: How do I manually drop plugins into an eclipse install in 3.5M7? [message #335992 is a reply to message #335979] Tue, 12 May 2009 23:37 Go to previous messageGo to next message
I have found that I generally need to restart Eclipse with the -clean option
before the plug-ins are properly recognized in the dropins directory.
Namaste, Bruce
Re: How do I manually drop plugins into an eclipse install in 3.5M7? [message #336009 is a reply to message #335992] Wed, 13 May 2009 11:33 Go to previous message
Thanks Bruce! Restarting with the -clean option worked.
"Bruce Kelly" <Bruce.Kelly@andrew.com> wrote in message
news:gudf9c$rpu$1@build.eclipse.org...
>option before the plug-ins are properly recognized in the dropins
>directory.
> Namaste, Bruce
Previous Topic:ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
Next Topic:[Databinding] bind modify of text to boolean
Current Time: Fri Jul 25 00:43:40 EDT 2025
Powered by FUDForum. Page generated in 0.05190 seconds
