| Tabbed Properties Image Leaks? [message #335957] |
Mon, 11 May 2009 11:01  |
We are tracking some image leaks that occur when closing / opening
editors. They seem to be coming from the icons on the properties tabs.
Sleak is reporting leaks of the images we contribute via the
org.eclipse.ui.views.properties.tabbed extension. Below I've pasted a
snippet of a stack trace showing where these images are allocated.
I would like to verify whether these images are being disposed of
properly. We are providing the icons, but I'm not sure it is our
responsibility to dispose of them. Is there something I'm missing or is
there a reason for not disposing of them?
Charlie
at org.eclipse.swt.graphics.Device.new_Object(Device.java:806)
at org.eclipse.swt.graphics.Resource.init(Resource.java:85)
at org.eclipse.swt.graphics.Image.<init>(Image.java:735)
org.eclipse.jface.resource.URLImageDescriptor.createImage(UR LImageDescriptor.java:162)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:227)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:205)
org.eclipse.ui.internal.views.properties.tabbed.view.TabDesc riptor. <init>(TabDescriptor.java:79)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.readTabDescriptors(TabbedPropertyRegistry.ja va:364)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.getAllTabDescriptors(TabbedPropertyRegistry. java:342)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.getTabDescriptors(TabbedPropertyRegistry.jav a:283)
org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge.setInput(TabbedPropertySheetPage.java:695)
org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge.selectionChanged(TabbedPropertySheetPage.java:538)
FUDForum. Page generated in 0.04352 seconds
