Home » Eclipse Projects » Eclipse Platform » Running the Eclipse Help System in an external web app
Running the Eclipse Help System in an external web app [message #335925] Sat, 09 May 2009 05:13 Go to next message
Originally posted by: jonatan.ogdo.frich.dk
I have seen that IBM (and others) seems to have ripped out the Eclipse Help
System and
placed it in an standalone web application. And I want to do the same!
I have a Jetty web server that hosts my application and I want to add the
Help System to my app.
How can I do that?
Pointers and any other help is appreciated
thanx
J
Re: Running the Eclipse Help System in an external web app [message #335930 is a reply to message #335925] Sat, 09 May 2009 07:58 Go to previous messageGo to next message
And the answer was in the Eclipse Help System itself - obvious
My bad
BR
J
"Jonatan O" <jonatan.ogdo@frich.dk> skrev i meddelandet
news:gu3hfd$6gn$1@build.eclipse.org...
> Help System and
> How can I do that?
> thanx
> J
Re: Running the Eclipse Help System in an external web app [message #335934 is a reply to message #335930] Sat, 09 May 2009 10:50 Go to previous messageGo to next message
Well, it was not exactly what I wanted.
So any ideas is still appreciated
J
news:gu3r5n$tqr$1@build.eclipse.org...
> My bad
> BR
> J
>> Help System and
>> How can I do that?
>> thanx
>> J
Re: Running the Eclipse Help System in an external web app [message #335936 is a reply to message #335925] Sat, 09 May 2009 13:23 Go to previous message
Originally posted by: nospam_kowalskilee.gmail.com
First, fyi, there is an Eclipse newsgroup that's specific for
questions/discussion about the Eclipse Help System at:
eclipse.platform.ua
If you repost your initial message to that newsgroup, you'll get more
people who would respond. There are people who follow that newsgroup
have done what I think you want to do.
And when you repost to that newsgroup, would you clarify more about what
you want to do and your scenario that you think is not answered in the
Eclipse help docs? It sounds to me that you have the following scenario:
- You have a Web application that runs in a Jetty web server
- You want to provide a help system for that Web application, and have
it run in the same Jetty web server so your application can easily talk
to it
Is that an accurate description of your scenario?
If not, then can you name the examples from IBM that you think match
what you are trying to accomplish? That way, we could see an example of
what you are aiming to do?
If so, then it seems to me that you want to use what is called
"Deploying the infocenter as a Web Archive" in the Eclipse help docs:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_war.htm
Have you read that topic to see if it meets the needs of your scenario?
Hope this helps,
Lee Anne
http://www.linkedin.com/in/leeannekowalski
Jonatan O wrote:
> System and
> How can I do that?
> thanx
> J
Previous Topic:Update-Site over https
Next Topic:can't see text cursor
Current Time: Thu Nov 20 13:53:52 EST 2025
Powered by FUDForum. Page generated in 0.03789 seconds
