Home » Eclipse Projects » Eclipse Platform » Contributing RulerDoubleClick action to nested text editor
Contributing RulerDoubleClick action to nested text editor [message #335863] Wed, 06 May 2009 10:03 Go to next message
I have a code editor nested in a FormEditor. I want to enable
double-click -> toggle breakpoint.
In a non-multipage editor, it seems that I could do this using
o.e.ui.editorActions, specifying the targetID to match the editor ID.
Then my action would declare its action ID as RulerDoubleClick. But in
the nested case, I can't really specify the nested editor ID.
I'm able to register the ToggleBreakpointAction programmatically, but
I'd prefer not to have to touch the nested editor, or put a debug.ui
dependency on it.
Any suggestions on how to contribute this action from my debug plugin,
declaratively or otherwise?
Cheers
Ben
Re: Contributing RulerDoubleClick action to nested text editor [message #335903 is a reply to message #335863] Fri, 08 May 2009 08:48 Go to previous messageGo to next message
Did you try it?
Dani
> dependency on it.
> Cheers
> Ben
Re: Contributing RulerDoubleClick action to nested text editor [message #335908 is a reply to message #335903] Fri, 08 May 2009 10:40 Go to previous messageGo to next message
I did. AbstractTextEditor#findContributedAction(..) is checking to make
sure the targetID matches the site ID. MultiPageEditorSite always
answers an empty ID.
> Did you try it?
> Dani
Re: Contributing RulerDoubleClick action to nested text editor [message #658648 is a reply to message #335908] Wed, 09 March 2011 06:45 Go to previous message
I have the same problem, but can you explain how to you have solved programmatically, I can't do it even that.
thanks
Previous Topic:ResourceChangeListener for Database Objects
Next Topic:How to : show 'Review Licenses' window every time?
Current Time: Tue Jul 22 15:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
