| Eclipse project structure [message #335823] |
Fri, 01 May 2009 19:16  |
Originally posted by: jean.bovet.oracle.com
I am currently evaluating Eclipse to create an RCP version of our current
Swing application and I have a few questions concerning the way Eclipse
handles project structures:
1) In our build structure (maven), the source and resources are in separate
folders (src/main/java and src/main/resources). How can I configure Eclipse
in order to have the eclipse-project specific files (.project, .classpath)
in src/main/eclipse while having the resources in src/main/resources (e.g.
meta-inf, plugin.xml) and the code in src/main/java? I am able to link the
source files correctly but Eclipse refuses to consider the plugin as a
bundle as long as the meta-inf/MANIFEST.MF is located in src/main/resources.
Any suggestion if it is possible to achieve this setup?
2) Is it possible to specify an output folder outside the project folder?
3) All our project dependencies are located in a repository somewhere in the
disk. In the Eclipse plugin runtime settings page, the Classpath section
allows only to specify libraries located in the project (it is an RCP plugin
project). Is there a way to specify a library that is located outside a
project in the runtime classpath?
Thanks a lot,
Jean
| Re: Eclipse project structure [message #335855 is a reply to message #335823] |
Tue, 05 May 2009 11:21   |
Jean Bovet wrote:
No, the Eclipse-specific files need to be in the specific places (mostly
in the root of the project, except for manifest.mf which must be under
meta-inf. These are "bootstrap" files that Eclipse has to know exactly
where to kind in order to know what kind of project it is and how to
handle it.
There is a feature request to allow some flexibility in the placement of
some of these files, but it is not something that will be implemented
soon (ie, not for the upcoming 3.5 release).
There are usually ways to structure the Eclipse Project (note the
capital P) to get along with an existing project (not the little p)
structure. The Help has a tutorial under the Java Development guide
(online version is here:
http://help.eclipse.org/ganymede/topic/org.eclipse.jdt.doc.u ser/gettingStarted/qs-ProjectConfiguration.htm)
For example, if the root of your project structure is MyProject/ then
you would ideally have this:
MyProject/
.project
.classpath
plugin.xml
plugin.properties
meta-inf/
MANIFEST.MF
src/
main/
java/
<.java files live under here>
resources/
<non-Java files live here>
Normally, everything there would be checked in. If you explain exactly
why that kind of structure does not work for you, we might be able to
offer work-arounds or alternative solutions to satisfy your existing
project needs.
Hope this helps,
Eric
FUDForum. Page generated in 0.03975 seconds
