Home » Eclipse Projects » Eclipse Platform » Export plugin
Export plugin [message #335801] Thu, 30 April 2009 10:29
I'm an eclipse plugin developer. Recently I was wrote an export wizard
plugin. So trigger the export dialog from the menu and select my export
item listed there and click next. The problem is that if I click previous
to go back to the export dialog it shows a blank dialog. neither the
filter text box nor the tree view of the export methods are shown. I tried
everything to find the problem but so far was unsuccessfull. Here is the
simpler version of the plugin I've tried out.
plugin.xml
<plugin>
<extension
point="org.eclipse.ui.exportWizards">
<wizard id="test_project" name="test"
class="TestExportWizard">
</wizard>
</extension>
</plugin>
TestExportWizard.java
public class TestExportWizard extends Wizard implements IExportWizard{
public void addPages() {
addPage(new TestExportWizardPage("my page"));
public boolean performFinish() {
return false;
public void init(IWorkbench arg0, IStructuredSelection arg1) {
TestExportWizardPage.java
public class TestExportWizardPage extends WizardPage{
protected TestExportWizardPage(String pageName) {
super(pageName);
public void createControl(Composite arg0) {
//some UI stuff
setControl(arg0);
Any help is very much appreciated.
Thank you,
Saminda
Previous Topic:Export plugin
Next Topic:Key binding sequence in label
Current Time: Fri Jul 18 05:58:25 EDT 2025
Powered by FUDForum. Page generated in 0.07448 seconds
