Home » Modeling » Papyrus » missing button applying default appearance settings?
missing button applying default appearance settings? [message #1806913] Fri, 17 May 2019 09:51 Go to next message
I'am looking for a button which removes all the dedicated appearance settings on a graphical object. The object should have default appearance settings as defined in the CSS file. Is this button well hidden or isnt it implemented yet?
Hoa
Re: missing button applying default appearance settings? [message #1806920 is a reply to message #1806913] Fri, 17 May 2019 11:46 Go to previous messageGo to next message
The button is in the "Style" tab of the properties view, and is called "Default style". It will remove all persisted styling properties from the selected diagram elements, recursively (So that will affect the entire diagram when you don't select anything), and CSS values will then be used instead.
HTH,
Camille
Re: missing button applying default appearance settings? [message #1806985 is a reply to message #1806920] Mon, 20 May 2019 12:32 Go to previous message
thanks, I was looking for this button in the appearance tap.
Previous Topic:ClassDiagram: Show stereotype on association's targetRole Label
Next Topic:Generating PDF-Documentation of a Papyrus-Model
Current Time: Mon Jul 14 07:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.05315 seconds
